wet the knot
melno
Hey guys
Help me if i'am wrong. I have always when making any knot, even on hook, i wet my line before pulling it tightly. If one makes a knot and pull it tight on dry line, it weakens it. Cuts into the line......
Is this true or just a story one told me many many moons ago??????
Have seen guys lost fish where line broke just above the knot.
Yes it is 100% correct and even more so if you are in a hurry.
The friction in the coils of a knot is high and if you pull the knot tight in a hurry before it is lubricated you will actually burn the nylon.
Wet the knot at all times just to make sure.
BOEPENSIE
Lube that line properly before tightening the knot, otherwise you WILL loose that big one. Ask me, I did a rush job on a top shot to braid backing knot and paid the price.
Def-e-nition
If you have a bucket - Finish off any clinch Knot , In the bucket , submerged under Water .
I'm no expert at anything , But i can Tell you that i spend many , Many , hours , in my garage , testing Knots and Making traces until well into The a.m .
You will notice a distinct difference in the Knots' finished off look , and if The knot holds under water , i Can Assure you the Knot will Not fail during a critical time .
In rare instances the knot will not fail simply due to it's inherent Thickness - a badly tied Knot in .9 - 1.2 mm Line , will not be nearly as Weak as a hastily tied Knot in .5 -.7 , as example . It is Only then , by sheer luck alone , and the nature of The thickness of The line compensating for not wetting the Knot , that it doesn't fail .
by burning the coil Area , as Enigma said , you are affecting the Knot's Inherent strength and Breaking capacity .
Def
