Well ? Would you ? I'm considering having someo
Def-e-nition
Well ? Would you ?
I'm considering having someone like enigma Shorten  One Of My dipstokke by around a Half - 3/4 foot in length .
 This Means a T53 /7 Now becomes a 13'6" instead of a currently running 14Ft 6" .
My question to you , is :
Would you trim , or would you sell to Someone else , and start from Scratch .
Chaps ?
Fluffy
If you know the rod and trust it i would trim it....
if i could sell for money and get a 3 piece i would just order another tip and shorten the tip.
yours a 1 piece??
Foxhat
Trimming and altering rods changes the characteristics of a rod in a big way.
Sometimes the rod magically transforms into your favorite, on the other hand chopping that extra inch off the front ruins the rod.
I chop and join rods quite a bit, I hate 14 foot rods. Even the ESA guys can't hold those rods up when their fish is pulling! I've seen it on TV, that's no way to fight a fish. Long rods with no action are back breakers. There's plenty of pics on Sealine of reputable fisherman battling with a long rod and a mediocre fish on the other end.
I personally think good advertising is causing a lot of fisherman to fish with the incorrectly selected tackle. A good rod should provide action from your hand to the tip, not just the top 3 feet
Def-
From my point of view as the builder, PLEASE sell it and build a new purpose rod from scratch. To re build a rod means stripping it all the way down to the raw blank because changing the back changes the action meaning the guides have to be re-seated to match the new rod action.
Removing the guide leaves unsightly marks needing the whole rod to be stripped and cleaned and if so desired, re-sprayed.
Shortening the blank should be done from the back only, as Foxhat says, shortening the tip even by 5cm changes the blank radically and can destroy it as a fishing rod. Some rods can lose 3-5cm from the tip plus another 30 from the butt and still be great but this requires some measuring and test curve testing before cutting.
YOu are saving on not buying a new blank but you are going to be charged for stripping, re-spray, new butting components etc - Your gear is top nick so find a good uyer and we can make a plan for you with a purpose built T53/7 or better yet a T-Flex /7 Slimline in 13'
purglaspete
before doing anything as drastic as cutting a rod blank that you think is too long just move the reel seat further up the rod so when you are casting it it is a shorter length above the hand see how you go on if this is better then you could think about actually cutting the blank , and as enigma said do not cut anything off the tipas this will ruin the built in action . that is the reason why I like purglas rods is that they bend right through to the butt  yet they will still throw a weight a long way . I have many pictures of the rods casting weights and showing how far they will bend
purglaspete
the rod is a purglass 4004/6 two piece I have cast  300gramms with it 211yards
Def-e-nition
Oh My Hat .
I Just got Off the Phone again with the rod builder .
Ai , you guys are helpful , I'm Like a Kid in a toy Store Wanting to sever 8" off this damn 14'6" .
I agree completely with foxhat In that incorrect advertising has Resulted in Influencing Peoples decisions Regarding Rod Choice .
funny , I'm always starteld when one stumbles upon the realization , of finally coming round full circle .................eh ??!!
Expensive journey it is , too .
donnnnnkey .
From a Blue Marlin 6-8 , then to a Loomis 2534-50T,then an Assassin Beachmaster 13'8" ft ,Then a Loomis Sharkey 13'6"ft , then the 14'6" "Must-have it" t53 /7 Custom , then ahhh - a Hennie papenfuss 14' 2" , then A poseidon medium heavy ,then a Mango donated Purglass 400/3 Masterpiece Purglass , then a AFAW 13ft ( which is what started this all over again !! ) , and Now fishing with the sharkey , it's almost as if fishing has started all over again for me ...
Whatta ride Though , eh !!??? !! lol KaChhhiinnnngg !!!!
Sure - On the Edibles rods- i reckon a 14+ is almost an Absolute Must-have .
but when Neuking around with these Monsters of the Deep n Dark - who the hell ever showed me or Told Me a 14' 6"ft was a "serious Shark rod , That ..." should be taken into a field - and shot ! .
Enigma - talk to Me about Price please ...... 365 /7 for dem fish dat makes short work of my Lower back , please .
Foxhat
I'll give you a good test.
Take your heavy duty rod and attach your line to a 10Kg object.
Imagine you are lifting it out of the water from 6 foot up and throwing it behind you onto the pier 20feet away.
If you cannot accomplish that then the rod is not ideal for heavy fishing.
I can do this with a 350/2 purglass.
purglaspete
a man after my own heart , rods that only bend in the tip are only good for small fish , I know that they can handle big fish but the rod actually works against you .where as a rod that bends right through works for you in killing a big fish the leverage against you is less as the rod hoops over and acts as a giant shock absorber tiring the fish out quicker
Def-e-nition
you Mean Dead-ligting a 10kg Object ?
a Pocket of Potatoes   ??  YOh ....
Are you serious About a /2 rod doing that ??
purglaspete
from what I have read on your discussion the results bear out what I was on about in that a rod that bends well is more comfortable in the fighting of fish it might not bring the line in as quick as a stiff rod , but who cares , if you have to straight stick a rod at a fish the rod is useless and has no part in the fight you may as well fasten the reel to a post . casting wise my purglas rods have cast 150gramm up to 275yards , 175gramms up to 259yards  and 10.5 oz 211yards  so the rods are not exactly weak these are two piece rods . I like powerful but bendy rods with a through action ,not tip actioned . its like in boat fishing stand up sticks realy hammerthe fish the americans call them short strokes as you only retrieve a small amount of line at each stroke but you are more in charge of whats going on .
Def-e-nition
right chaps .
Perhaps i should indugle you with the result .
i took in the 400/7 , and had 6"Lobbed off it . From the butt section , in the handle . the rod now tips the scale as a 13'7"Maybe closer to 13'8".
suffice to say , it went/came with to witsand . I was not able to stretch it until the sunday .......
The eyes have not been moved , as , as enigma said - you have to take the rod down all the way to the blank , it leaves unsightly's , etc .
right .
so the flip up is reasonably Low down - no big hassle , i can move it Later if it becomes a bother .
Anyone who witnessed sundays fight at jongens, and again sunday's fight on voelklip , will easily attest to the Fact of how happy i am wth the new Gun ......
Holy Mackeral .
I am a convert . Long stiff rods for sharks went against every grain of Knowledge and practise that i could Think of . i am Not in the Least bit sorry that i had the rod cusomtised . Dummy did an Excellent job at retrieving the rod from extinction , and suffice to sa i basically went Looking for the biggest , baddest , hiding that i could find , and it handled brilliantly .I Left the tip as is , and shortened Only The butt section(man , the handle , ya'll know what i Mean .)
So against your experienced and better judgement , enigma , I am both Relieved , and happy, to say that my bum was itching to do Something to the rod besides just sell it , and that the Experiment worked , and , as foxhat sas "the rod has instantly become My most Favourite big gun of all time for hunting down In-eds ......
haleluah
Def-e-nition
Enigma wrote:
Def-
Now That's an interesting combo that i haven't Thought of before . Nice .
 That sounds very very Much like the AFAW 13ft Rock rod I am getting from whaler,soft front tip with a strong mid section , but , generally , a whippyer Action than a straight T53/7 . And  in 13 ft , would Make a nice Addition to someone wanting a firm rod with some great tip action ....
Nice enigma . that'd sell .
Why do you think the Purglas 350/6 is selling so well? 12'10" rock like base, flex in the middle and whipy tip.
Slides super fast pulls a smouthound across the top of the water and puts the heat to any big fish on a Tn50 with that rock solid bas 1/3 of the rod.
between an Extreme Med and Ext Heavy (/7 = Ext Heavy)
200gr heavier but when you have 100kg pissed of Toothy critter on the end all rods suddenly become very heavy (as heavy as the shark makes it)
