Water retention problems with braided lines- Any solutions?
Buffalo Hunter
Hi Guys,
PS - I have done a search but came up with nothing.
How do you guys combat the water retention problems with braid on your reels? Irrespective of thorough cleaning with warm soapy water after each trip and spraying with water displacement sprays, I still seem to have problems. I also give the reel ample time to dry before storage.
When removing the top line for replacing, invariably there is an accumulation of salt at the mark where the braid begins. I had a Trinidad spool replaced under warranty because of pitting on the anodised spool. I became worried and removed the line from my Torsa and there were signs of the early onset of corrosion. This morning I removed the line from my Shimano TSM4 and noticed the accumulation of salt at the braid mark as well. It would not cause this spool any harm but it has alerted me to possible corrosion problems on metal spools, even if it is anodised.
I have since sprayed my spools anti corrosion spray prior to loading braid to see if it stop the problem. The jury is still out on the result.
I treasure my reels but I would hate to think that you would have to regularly take off the line after serious fishing trips.
I am really interested to hear your thoughts and a possible solution.
Regards,
BH
tintin1
What I have tried and seems to work quite well is to use a good car polish on the spool before you fill with line.  Do a couple of coats, let them sit a day or so to cure and you should not ever have the salt pitting problem.
While you are at it, clean out the rivet areas on your reel seat (acetone) and then put a little slow-curing epoxy  on these areas.  When filled with epoxy there will be no tendancy for the salt water to drag in by capilliary action and there is another source of corrosion gone.
