Waft venom.
Absolutely awesome blank.
Casts really well, little heavy action but can swing a Yellowtail
Guide layout very much a KR concept
Good rings on the guides but the rod definitely ups a notch in performance at the pricey upgrade to Fuji KR guide train.
Eli has one that he has fished standard and with KR layout and I've fished a number of times with Johan Beukes's one off the Island at Mazeppa
vvt_freak
I'm nowhere near enigma's pedigree but what I can say is that it's an awesome rod. I have a slim line which I only use for eds but I can comfortably throw 6oz with biggish bait. Only small problem I had was the bottom reel clamp cracked because it's plastic. just somehow re-enforce that and you're good to go.
Ray11
Im concerned about that whole reel seat cracking thing again. I thought they were only on the iron feathers.
99.9% of the crack reel seats on both the ranges you mentioned that I have repaired have been as a result of overtightening ie. User ERROR
Ray11
Don't take this the wrong way. But I thinks these rods are beautiful. My only issue is when I mention waft, always someone had a cracked reel seat. Many rod brands sometimes suffer defects. But why are these gorgeous rods seseptable to cracking. Like the earlier comment. Its kinda concerning to know that if I buy this rod I will have to worry about the reel seat. Or is it just me. Because I had the same issue with my waft iron feather paired with a fathom 15 and never over tightened it.I thought perhaps the venom is better in terms of that specific issue.
vvt_freak
let me put it this way....
My cracked reel seat would have been too much of an effort to fix.Not to mention the cost of getting a rod builder to do the work. Cutting off butt section then having to replace and then rebuild butt.
I did a R2.50 McGuyver. Went to a motor spares place and bought a hose clamp. The kind with a screw in it to tighten on radiator hoses.
Now my venom works perfectly.
