Naruto
Enigma wrote:
1. His water to feed ratio is not always right. The feed is too wet most of the time.
2. His casting action is sometime jerky and not always accurate. The jerkyness can cause the soft feed to be cast off more easily.
3. And all this causes him too loose time and then he gets over eager. His haste causes him to consentrate even less on putting on his bom properly and the whole cycles gets repeated.
Worst of all is that On the days his feed is good, he can outfish most guys in the club.
What I have picked up from what he does wrong are the following:All the feeds on the market are good and come from only 3 or 4 producers.
I fish with Carp World or Champion popcorn or SuperCast or whatever.
How the feed is made isn't really the reason that the bol is cast of. It's in 90% of the cases how the bol is put on the bait carrier (spring or weight)
Naruto your father probably catches less not because he casts the bol of but because in casting off he doesn't gain a rhythm in casting and spreads the baits cast of around as well as those not cast of as well. If his bolle are being cast off because they are not put on properly then the bol will also spiral and fly in an angular direction if not on properly.
This all results in an innacurate feeding area that doesn't concentrate the fish and cause competition for food.
