Vertical Jigging/dropshotting
Bushbuck
I have done a lot of Bottom fishing in the EC using bait in and around Port Alfred area. I want to try some vertical jigging and dropshotting. I have 2 spinning rods, 8 foot exage with stradic 8000 and 50lb braid and 8 foot (can remember the name) 3oz spinning rod with a 4000 sedona (normally used for leerie fishing)
I have a lot of plastics, paddletails, minnows etc (what weight leadheads do i need to fish up to about 30m. I have also got, for jigging, those little squid with a sing hook, and two williams vertical jiggs, one small stock one and one slender one. between 2 and 3 oz.
Im sure the kob will klap them but what else can i target and are there any specific retrieves that u can suggest.
foot soldier
swivel to mainline,1 to 1.5 meters of heavy trace line to sinker of your choice,you can go as heavy as you like,,work out high up off the bottom you want your plastic(increase length of leader if you want it to sit higher than 1.5 metres),,then you need a hook with a straight eye,not offset,weedless worm hooks are best but a mustad big gun does the job,,,between the swivel and sinker you need to tie the hook on with a polmar knot(hook facing up) keep the hook atleast 30cm below the swivel,id recomend more,,the beauty of this rig is your plastic has no weight to hinder it,you can make it dance the same whether using a 1 ounce or a 10 ounce sinker,,,if your fishing heavy reef,instead of tying your sinker direct to heavy leader run another swivel below your plastic and tie your sinker to that with a lighter line than your mainline,if you get snagged youl only lose a sinker and not the whole rig
Jannus.
Hi bushbuck, I am in the eastern cape and have fished 3 times so far off of my kayak. I did not want to use bait for fear of atracting sharks and because bait is messy. Art lure is very convenient.
ok back to the fishing, I have used the squid jig with nice success sofar, I caught a smallish piggy, a 44 cm soldier and a 40 cm dageraad on it. It works well with a large arch in a jigging up and down motion.
on the dropshot side i actually used a clouser minnow used for fly fishing. I used it in a droper style, and boy did it produce. first down i CAR a 33 cm greasy rockcod. next i caught 3 small frans madam. Then for the cherry on the cake a 52 cm poensie!! all released.
with the clouser I jigged in a big arch. hope you go vas
I do believe that a kob would love the squid as well as the clouser
Jannus
