With my
acquisition of a 5000 grinder and an Assasin spinning rod, and utilising braid/mono leader with a 'no-name' (Bristol) knot, I have dragged out the bag the tube of UV Knot Sense.
Applied same to said no-name/Bristol.
An old product, very usefull, to prevent friction and knot wear and tare.
Who of you utilise this product?
With UV Knot Sense you can smooth and strengthen your newly tied knots immediately. After application, it dries instantly with Loon's UV Mini Lamp, UV Power Light or with direct sunlight. Also works great for repairing damaged flies and completing household projects.
Features
- Ideal for coating knots for strength[/*]
- Smoothes knots to easily slide through guides[/*]
- Cures soft and pliable[/*]
- Instantly cures with sunlight or UV light[/*]
- Quickly repairs damaged flies
How To Use
- While shaded from the sun, apply enough UV Knot Sense to coat knots[/*]
- Rotate line or use applicator to form UV Knot Sense to desired shape[/*]
- Expose to sun light or use Loon's UV Mini Lamp or UV Power Light to cure[/*]
- In direct sun (or when using Loon's UV Lights) hardening should take approximately 15 seconds
Ideal Uses
