I saw something on a NZ fishing site a long time back about using hollow core dacron as a protective sheath when knotting braid ...
Cut off a 30cm hollow dactron (50lb test). With thin fishing wire, pull your 50lb test braid line (doubled) through the dacron sheath. Pull the braid loop through and make a simple overhand knot at the end so that you have a bit of doubled braid loop sticking out, the dacron sheath up your doubled braid. Now join the doubled braid enclosed with the dacron sheath to your shockleader using the 3 - 5 loop double centauri knot in both lines, braid and mono, cut off tag ends (including the portion with the overhand knot at the one end and the now superfluous braid tag at the other end by pushing the loose end of the dacron sheath to the knot). Push back the dacron sheath up the braid line. You could just leave the sheath like that or "serve" the loose end to the braid with dental floss ...
It might take a bit of trial and error to get the dacron length just right for the knot you use, but this should give you a smallish strong knot with the braid protected by dacron. This knot should also not slip as easly as braid on its own and could also be used for braid to braid joins ...
Just a thought ...
Where are the braid testers? Exavier? GL? Anyone?
Just a thought ...
