I read this in another thread -
`The trick is a launch rope. Get yourself 20m of say 25/30mm rope, and you can then launch from a distance from the slip and avoid the kelp, slipery section etc. Works really well, it just takes a few extra minutes to chock the wheels & set up. This also lets you walk the trailer right into the water, and then pull it out without getting the car wet.'
Quick question - to use a launch rope does one tie one end to the trailer and the other end to one's towbar? What is chocking the wheels?
