Tyrnos?
ICTHYES
What do you think ?
(Note taken from a SA site.)The Tyrnos is a durable heavy duty multiplier with a huge high-ratio gear system, developed in response to the dealer complaint that multipliers are too slow. The one-piece aluminium frame Corvalus is expected to be a "market breaker" in terms of quality for price.
TYRNOS
The Tyrnos® and the The Tyrnos® 2-Speed have the features you need for heavy-duty saltwater fishing, from kingfish to tuna to marlin. The solid one-piece construction, lever drag system and high-speed gear ratio are designed to perform under extreme pressure.
  • Features
  • Topless Design (12, 16 and 12II, 16II sizes only) [/*]
  • Reduced Profile Top Crossbar (20, 30 and 20II, 30II sizes only) [/*]
  • Oversized Gears [/*]
  • Oversized Handle Shank [/*]
  • Diecast Aluminum Frame [/*]
  • Alternating Twin Pawl Anti-Reverse Design [/*]
  • Graphite Sideplates with Aluminum Braces [/*]
  • Harness Fishing Accessory Handle (20II and 30II models only) [/*]
Noweeds
Robbies got one for swim baits....but when you take its size and line capacity into consideration i would rather have a trinidad 50!
sharkbyte
This reel would be used by Boat Fishermen mostly.... i have afriend ho uses them and when he is in the mood for kuk he will try to catch a Tunny with it....
The lever drag is not too bad a friend of mine bought a tica reel similar to the shimano in malaysia and its the same size as the torium...  and it casts like a donkey... a bit heavy dont get the distances but man the smooth drag and powerfull retrieve is awesome the model escape me but i will check and show pic of it soon!
Noweeds
The Tyranos actually has a smaller spool than the Trini 50......at the end of the day i would rather have a trini 50 which i can cast and holds more line!!!
lerouxjaco
The Tyrnos is a excellent reel for offshore fishing, won't recommend it for surf casting as a Torium or Trinidad will do the job a lot better. This reel is perfect for jigging due to the line retrievel per crank 45 inches. Compared with the Torium and Trinidad it's got a lever drag and harness loops for the big one's which I prefer and drag setting is the same (33LB) as the Trinidad50, line capacity is less. Keep this reel for the boat rather.
Hammertime
Have two Tyrnos on board.
Caught more 50+kg tuna on them than I care to remember.
My first reel of choice for off shore league on 10kg, coupled to an stp 15-24kg stick
Fish them socially on 24kg and will take it any time to a tuna fight. They have both accounted for some big fish.
I think as far as off-shore is concerned the drag is one of the best I have felt.::coolsmile:
lerouxjaco
Have to agree with you on that HT for the price you pay for these Tyrnos reels you do get a lot for your bucks. The Tyrnos compares well even with the likes of the Tiagra 30 specs which is a top reel in it's own right just a lot higher priced. I went for the Torium 30 rather than the Tyrnos 30 due to the fact that I wanted to use the reel for surf as well as jigging offshore and the Torium can be used for both applications where the Tyrnos is'nt really a casting reel although you can cast it by using the lever drag to prevent overspooling, have done it with the TLD 25 lever drag reels fishing live baits in river mouths such as Tugela etc got about 50 meters out of the reel with a 8 FT boat rod, kept the rod short for more power. I don't think the Tyrnos will do much more than 100m casting, you guys is welcome to comment on this, will be interesting to know how far one can cast a lever drag if you know what you are doing. Hope that one of my TLD's will pack up soon so that I will have a good reason to buy the Tyrnos, but I suppose that's wishfull thinking as these reels doesn't break that easily.
