after reading the topic about distance on Sealine i was wondering how far i cast with my slide gear
I know where a normal edible rod and light line gets me but i have never measured the heavier rods and lines-
I manage to hire a 100m tape measure in town and wih my personal assistants(Thea and the rottis) we went to Kleinkrantz beach
i measured the distances up to 150m on the beach and with that done i started casting-eish my arm were moeg near te end
i uses my Penatagon (hy's soos n besmstok) mostly and i made a few cast with my Gremlins shark extreme witch are a really short rod more suitable for rocky deepwater points
I made between 3-7 cast per different rod and reel to measure the best distance)
weatherwise it was overcast with a side on wind of about 10knoths
first the Penatgon with a trini50, loaded with .60 Kingfisher and a 1mm windon leader, 9oz weight with grapnel wire--BEST distance 115m
IMG]http://i28.tinypic.com/egxw9k.jpg[/IMG]
my pragtige teef Giga
IMG]http://i27.tinypic.com/oacfgg.jpg[/IMG]
en die reen STUKA
second also with the Pentagon , Trini 40 with .55 Double x HA , 1mmwindon leader and 9oz slide weight with grapnel wire -BEST distance 120m
trying to bend it properly
just giving my arms a bit of a rest
IMG]http://i32.tinypic.com/2rhw8hx.jpg[/IMG]
wat sal n paar gooie nou wees sonder n KRAAINES............?
die 3de opsie wat ek probeer het is met my ou Toruim 30 wat ek nie meer rerig gebruik nie en hy het ook die ligste lyn van al gehad
Pentagon met Toruim 30 . 50 diawa lyn , 1mm windon leader met 9 oz slide sinker met draad-BESTE afstand 125m
Penatgon met Toruim 30, .50 Diawa lyn, .65 leader( not a windon) and a 6oz cone sinker -best distance 138m
lastly my fav sliding optiion
Pentagon with Trini 30, .55 double x HA line, 1.6mm windon leader and 9oz weight--BEST distance 120m
all in all what i can say is with heavy gear you dont get tht far, with edible gear i can get it over 180m with the thicker lines and windon leader i could only manage 138m
and also that a cone sinker travel way better through mid air compared to a slide sinker
en die reen STUKA
