Trinidad 40 vs 50
Weedeater
Been wondering a while now about buying a Trini 40 for targeting big sharks using swim baits.
My question is, is the 40 worth buying as opposed to the 50? The primary reason for wanting to go for the 40, is managability. The 40 is easier to use generally than the 50, due to the narrower frame. But with line capacity of around 900m on the 40, its only 100m more than the max on my Saltist 50H.
Worth getting the 40 or just bite the bullet and go for the 'beast' of a 50?
Raggieman
Regardles of the model they all cost the same 30,40 and 50
only extra expense between the two would be the Braid backing - Ask Nowweds what it cost to fill his 50
Weedeater
Hi Raggie,
Not worried about price, not an issue. The size and ease of use of the reel, however are. I'm not keen on the 50 as its very bulky and not the easiest reel to cast with.
How much line with backing have you got on your 40 compared to the 30? The braid backing is also not an issue, will just order a bulk spool of PowerPro from the U.S.
Drenalinjunkie82
Weedeater,
I cast my 50 no problem. Takes a bit of practice but its worth it. You can cast mine a bit if you want to. Where in JHB are you?
christodeb
Hey Weedy get yourself the 50, the 40 wil have the same casting "problem" as the 50 due to the spool diameter. The spool diameter is exactly the same with both reels. I fish with the torium 50 and yes it is not as easy to cast as a 30, but i still got enough distance to catch a few bronzies in henties.
Weedeater
Hey Christo,
Thanks, that's what I was looking for, question answered. The 50 it is then. The PowerPro bulk spools should be perfect for the Trini 50 and would be a good match for my Assassin Heavy HMG.
Hey Drenaline,
Check your PM's, appreciate the offer! ;)
