Trinidad 40 handle assembly
Def-e-nition
well , I've only opened it once , but after it finally collapsed i had to find some bearings from enigma
Now try as i might , i can't seem to find schematic or pics of what the handle should contain . First bearing slid in , but I've a suspicion the second bearing is wrong size , although these two bearings were found after a LOT of searching on enigma's part .
Anyone got any advice where i can find this info , or just be so kind as to pop open their handle and take a pic of the first bearing on the shaft , handle side ? This is driving me completely nuts .
Thank you.
Def
Sorry, I was incorrectly informed on the Bearing sizes
Top is 4(ID)x 7(OD) x 2.5(Thickness) bottom is 5x8x2.5.
You short the 4x7x2.5 will see if we got 1 here
