Trinidad 30a
Corkscrew
Hi guys I recently bought a TN30a spooled it with 600m 50ib HMP braid and 200m 0.47mm Double X Mono. My Casting distance I achieve is 130m average with overhead cast and a 7oz sinker also have to say with a lot of thumbing. Do you guys think it's necessary to Mag my reel to achieve further distance or is my distance sufficient?
robyosh
I would say it`s enough as you`ll get used to it the more you use it.
Secondly alot of people cast over the fish just keep it in mind.
If it`s going to make you feel more confident do it else just use it as is in the mean time and see what the time does.
Corkscrew
Hi Rob, that's what I'm figuring as well. I'm not getting overwinds, but have to thumb it a bit. I must say this reel casts like a dream. If I'm not getting overwinds I don't think it's necessary to mag the reel as I can control it.
DJP
It does take some getting use to. One tends to get bundles mid cast more often with them. Try and casting higher and with a slower action. That will.reduce the thumbing and most likely only require a slight touch at the start of the sinker decent. Because you sinker will be traveling high you dont loose as much distance when thumbing it.
Corkscrew
I will def give it a try. I noticed that most of the thumbing takes place in mid decent. I load the rod nicely and have a smooth action, but when the sinker picks up speed I need to thumb it. I also need to say. with any other reel I normally loosen the spool until I can move it slightly from side to side, I would say 1mm or so. With the Trini I tightened the spool so that when I move the spool from side to side it only makes a click sound but doesn't seem to move.
