Trim&tilt required at PE launch sites??
The Boatman
Hi guys
Me asking questions again. I have my eyes on one of the boats for sale here on sealine. Mallards Swift 165 with 2 x 40hp Mercury engines without Trim and Tilt.
I'll mostly be launching from Noordhoek or the harbour. Only doing my skippers in 2 weeks so not to sure about stuff like trim&tilt during launching. How important is it for those launch sites especially for a novice like me?
Want to make sure I buy the right boat for the right job.
Thanks again for everybody that is always willing to help!!::S
neilg
for surf launching non trim motors are good
for noordhoek I would recommend trim & tilt, especially on spring low ...
Patrick
Hey apnearules, i wouldnt be put off the boat just because of no trim n tilt tho. The Mallards are great little boats. Trim n tilt is a very handy thing and makes boating easier, but its not compulsory for launching in shallow areas. Simply tilt your motors up manually and use the correct pin height until you've cleared the shallow areas. We launch from Buffels at Cape point and ask anyone that does, its a very shallow slip. I have trim n tilt but 2 boats I know of launch there without trim n tilt easily. Just get your settings right and off you go.
Sure it makes adjusting the boat easier for the type of sea you're in, but that can also be done with the pins.
The Boatman
So if I understand correctly the trim and tilt adjust the angle of the motors shaft and thus the depth into the water. So when it is shallow you can simple adjust by using trim and tilt and so prevent prop from hitting the bottom?
Thanks Neilg and Patrick for the info::S
