Trim Craft time for renovation
colemanjldj
Hi there.
I have a trim craft beep vee boat #0682 built 06 October 1980
it has two 25 hp Yammies on the back (648 series crica,1972).
She is very tired and needs to be refurbished.
The left rear motor started to leak on the gearbox, so as a precaution I have removed the motors, dismanteled had parts that where not available anymore(needle roller bearing bushes) made up, being a mechanic this is not a problem.
The hull its self, the transom was patched by somebody :fbash
years ago I have removed all the bad patch work,have replaced the ply on the inside and will then re glass the tail end. What can I use to paint the hull, she has a wet deck with center seating arrangement, I want to fit a center consul and move the arrangement arround.
Have a look at the pictures and let me know what your thoughts are
PS the Boat was last registered as U-C-3830 last cof was 2007, I can only presume that we will have to start the whole process from scratch.
Serra Moz
Nice project you got planned, update and post pics as you go along.
If you post in Starboard section under the boating topics you might get more replies?
Good luck!
