Tournament Pre-Fishing Tips
Fishton
With the BETT series including some ‘new’ dams this year, it is going to even the playing field out when it comes to ‘local knowledge’.  I am going to try and give you a ‘leg up’ on how to get ahead of the field using some tools that are available to us today.
First and foremost is Google Earth, try identify ‘unique’ areas from the satellite imagery and create waypoints using the Placemark Tool of the Points of Interest, or POI’s.
Tip:
Remember to create a folder FIRST, and in this case name it Woodstock Dam for example.  Keep all Paths, Placemarks and Image Overlays in this folder.
The next step is to get a sediment map of the area, available from Department of Water Affairs and Forestry.
Tip:
Try getting a digital copy, this will save you the hassle of converting the paper chart yourself.
Now you can overlay each section of the dam into GE (Google Earth), and calibrate it.
Tip:
Use easily identifiable objects such as roads wherever possible to ‘calibrate’ your overlay image accurately.  Don’t rely on a shoreline because it is nearly impossible to know for sure where the shoreline is from the charts.  You don’t necessarily have to do this for all the chart sections, as in this case there are 16 sections, just identify the areas you want to fish and do those.
Once you are done doing this you can start ‘fine tuning’ your POI list.  Let’s take this GE image for example, and try identifying which of these three channels could be possible ‘bass highways’:-
From the satellite photo channels 1 and 2 look really good with sharp defined edges.  But channel 3 looks a bit ‘weak’ and not that great.
But once you overlay the sediment chart you see that channel 1 is worth trying and channel 2 is totally useless because it just flattens out to nothing as it enters the water.  But channel 3 is now the #1 POI in this area as it has a defined ridge all the way out to near the centre of the bay, making it a first class bass highway.  You will still need to confirm this with your sonar though, and if it is still well defined look for some isolated cover (timber, rocks etc) along the edges using your SideScan.  And finally use your 50/200kHz conventional sonar and 800kHz DownScan to identify possible fish in the area.
Identifying POI's:-
[flash=425,344]http://www.youtube.com/v/eK84YTvOjBw&hl=en&fs=1[/flash]
Ryan
Uncle John great to seee you's still around - wishing you and your family all the very best for 2011.
Manna for yet another amazing post....
Blommie
Nice info John. Really valuable stuff, especially for Woodstock and Sterkfontein to come with the BETT. Do you have those contours of Woodstock in e-mailable format. I don't have the fancy side image finders and GPS' you guys have on your boats, but I can at least make an A1 plot of the map and have it laminated for the boat.
arab
great little video clip thanks, been wondering where i can get my hands on that kind of map for ages! but i was wondering if it was possible to get these sediment maps online, or do you have to go to the department its self for a copy ?
Fishton
Hi Blommie,
I have these charts for Woodstock, Alberts, Inanda, Wagendrift and busy with Midmar. R250 each.
The files are very big so I put it on CD and mail it to you. It comes with software and emulators so you can save and convert relevant info to any GPS.
Blommie
Just what I need.  I've got the ones for Inanda and Midmar, but would appreciate the ones for Woodstock and Alberts.  You're not by any chance fishing the BETT at Inanda this weekend?  If you're coming for that I can bring the cash along.  If not, send me a PM with your banking and other details.  Thanx John.
Blommie
Thanks for the CD John.  Works like a charm on my computer.  Will make an A1 plot and have it laminated for the boat.
