howzit guys!! my friend has a tor 20 which we are trying to get working properly. The problem is that when you tighten up the drag and start pulling every now and again you get a hectic noise ( a loud 'clicking' noise ) of some sort. it sounds as if something is slipping.
My guess is the roller clutch bearing is f&%)kd and is stuffing out when the drag pressure is high. Nothing else seems to be wrong with the reel. It feels smooth, all inner parts are in good order, besides the spool which has a ding in it. I did however notice the 1st drag washer on the main gear was a bit worn on the sides but this isnt the problem as i replaced his washers with mine and the problem persists.
Any advice would be greatly appreciated guys. I dont want to go out and replace the roller bearing if it isnt what the problem is.
