TORIUM 30
Bonez
Without the centrifugal braking system, does it mean that the Torium would be much harder to cast, like something similar to the old penn reels?
How would it feel for a novice fisherman or someone wanting to learn how to use a multiplier?
I would guess that without the braking system you would generally achieve greater distances when casting.
Bonez
Walt
Bonez
I haven't tried Tor30,but did try out a Tor20 on Sunday,and it doesn't cast anything like any of my Saltists or Grandwaves,and I got plenty of overwinds with Torium. So,think I'd fair even worse with Tor30.I was due to buy Tor 20 & Tor30 this week and went as far as ordering them,but since changed my mind and will settle only for Tor14.The retrieve on the Tor20 is really great & is definitely a strong reel,but too heavy/bulky for me & personally I prefer Daiwa.I've removed all brakes from my daiwas & it definitely helps with distance & I hardly get an overwind.But,admittedly,I only used Tor20 for a short period.But what I can't understand, and what really  turned me off,is why a new reel should need to be modified?For me to get modification would mean 2 trips of 50km each way,and getting time off from the office.So extra on top for Tor20 or 30 would mean an extra +/- R200 for gas + R180 for modification = +/-R380.And that excludes lost time at the office or any costs incurred should reel need returning as has been the case in some instances where reel never really worked properly as per one of the guys on this site.So,this Mod was the deciding factor whereby i've put Tor20 & Tor30 on hold. So,I'll settle for my Saltist 50H,30H & G/Wave, but have ordered a Tor14,as mentioned, as have heard great things about this Torium baby,which apparently has yielded some big fish & is everything but a baby.My 2c.Cheers!
Weedeater
Bonez
I haven't cast one, but yeah I would imagine so.
For a novice, you can't get better than a SL50SH-probably the best multiplier out there to learn on, plus they're very forgiving.
Bonez
Good point Walt
Seeing as though 'cash is king', I have little choice lol, but I think once getting used to the casting then i shouldn't have any regrets
bonez
skrops
Walt, I want to do both types of fishing. My budget only allows me to have one reel
Bonez
In a earlier post you said you don't really like Daiwa.........
so then get the Torium, nothing wrong with that reel, I did a couple casts a while ago with one and was impressed. you will get overwinds with any reel, ask me I know!!!
soon you get used to it. Shimano aftersales service is non existant but the reel itself is cheaper than the saltist 50, good value for money. buy it now before price go up......if they haven't already.
and with the Torium you will be able to catch eds and non eds.
Bonez
Thanx man. You guys give great advice! I will be buying the Torium this Friday, the price is still low so I wanna grab it now. I have set my mind now to get used to it and think I will be enjoying it soon after a good couple of casts. This is the first time I will be using a multiplier. So thanx again for the vote of confidence!!!
raggie hunter
believe me..when you hook a really big bus on a torium you will feel the difference..the sl50 is a very good casting reel and for edibles...but for sharks the torium is far better..if you still new in casting with a multiplier reel the sl 50 might be the answer,but for bigger fish i would prefer the torium..fishing at the platform a week ago,my friends spool on his sl 50 snapped..and the whole reel is shattered..happened to me on bluewater bay as well..luckily the damage was less...i know its a bit easier to cast with the daiwa,but when you are use to the torium you will get the cast to be better and better..load with braid and mono and you have a real machine of a reel..
Bonez
Interesting…
I wanted to load the reel with 18kg kingfisher nylon, it’s cheap and I won’t be kicking myself too hard if the dreaded over-wind haunts me, just until I get the hang of casting that is. I’m not too clued up on braid. What’s the good brands? Also what is a good breaking strain to get, and the mono?
Thanx Bonez
neilg
Berkley Whiplash is good for backing, expensive but good !
50lb braid and then yuor 18kg kingfisher on top - about 150-200m of the mono.
deisel
i got a torium 30 great reel, i als fish with a exage 1468 great rod if you dont get a dud, which i dout only im that unlucky, 120lb leader .55 giant abrasion and of you go, its a bit different to cast but much the same in most aspects just get used to it,once you can throw properly you can throw with any reel
skrops
Raggie hunter the guys was sold on the torium, but now I have to come in here.
I caught a 175kg raggie with my Grandwave no problems, at some stage during the fight the drag was so tight you could hear the line biting into the other line on the reel, still no problems and I still use it, still my fav reel. don't underate the cheaper(smaller) reels, they are just as tuff.
Weedeater
Agreed, believe you me, many a shark has been caught on an SL50. I just upgraded the drag washers to CarbonTex on mine and a power handle - the reel works like a bomb.
Make sure you put braid backing on your Torium, 600m Kingfisher Pro braid 45lb will set you back around R550 and then the topshot is your choice, I use .52 XX Hi-Vis.
That way if you get a serious overwind, cut it down to the braid and then top up again. Simple and effective!
RaggieHunter,
Your mate's spool that popped on the SL50, did he have only mono on the spool? If so, then that explains it. Mono has stretch and puts serious pressure on a spool if you're using only mono.
raggie hunter
he had braid as well...mine was a zambesie..and i think the fish was just to powerfull for any surfcasting reel..thats why i still fish my sl 50..but not for sharks..every reel has a different function..but his reel was a new daiwa..maybe a k@k one in the batch..he actually bought another sl50..he loves it..personal preference..
Weedeater
That's the first SL50 I've heard of that's had a spool pop, more interestingly with braid as backing! Could have been a faulty spool, plenty Penn's had it happen in the old days when they were using bakelite spools.
brendon muscat
Walt why don't you take one of my toriums for a test run no modifications the 1 reel is 3 years old and only profesionaly serviced once, just rinsed with fresh water and greased once in a while. still as smooth as the day i took it out of the box. Have a cast with that and then a daiwa and you'll see the difference. ( anyone whom has fished with me knows that my reels always end up submerged when wading.)
Walt
Hi Brendon.Thanx for the offer & perhaps let me know if & where you're fishing the weekend,and maybe we can hook up.If i can try your Tor30 for a couple of casts,you can use my saltist50H & there'll be no interference wrt fishing.Cheers!!
