Gunn@r wrote:
I want to catch leervis and elf
Since Reefman CLEARLY can't read ....
(camo worm ... huh you overeducated dentist)
For Elf and Leeries
PADDLETAIL PADDLETAIL AND ANOTHER PADDLE TAIL
- - Spoon - silver or brass, which ever shape (S-bend works for slow, V for fast)
- - Bucktail jigs
- - Plugs
- - Poppers
- - Swimming lures like Rapala and Onda and all the others
You can use plastics to target elf, but it's not economical, they will DESTROY them, for the elf hard lures work very well and it's not so hard on the pocket.
For leeries you can use all of them, from the soft stuff to the hard stuff ...
Both are mostly caught close to the surface, but there are times when they run "deep", so keep that in mind when targetting them.
Don't be scared to trawl a 10cm popper and a 6-7inch paddletail soft plastic behind your kayak. Stay as close as possible to the back of the waves but take care, you don't want yourself and kayak to end up between the waves.
EARLY MORNINGS AND LATE AFTERNOON.
Good luck and have fun
