to hmg or not
Brands734
i think its an amazing rod yes its expensive but it id definetly buy one if i had the money the rod is a pleasure to fish with and to pull fish with but its a bit hard to cast with it being so stiff i personaly think it is one of the best rod on the market if not the best
My 2c
Maestro
NAVZ wrote:
WHAT IS THE PURPOSE OF SUCH AN EXPENSIVE PIECE OF EQUIPMENT?
i'm sure that you asked the same question when graphite rods were introduced and guys were catching fish with heavy cane rods...technology develops, lighter materials are used, like the hmg material..rods are lighter, reel retrievels are faster, hooks are sharper and stronger and prices are higher...welcome to the world of material progression
Kumz
It takes some getting used to ...
I wud personally say test drive someone's 1st before buying one ...
Personally going forward ..i wud not change from HMG ..
my 2cs
Weedeater
[color="#006600"]Hooked[/color] wrote:
If u have to ask the question  then you probably dont need it :::S
Ha ha ha! Good point Hooked!
My advice, don't buy one because it's supposedly the top of the line Assassin HMG, alot of people have made this mistake without trying the rod out first and find it very hard to load/cast, most newcommers land up selling their's.
As the guys have said, see if you can test one (cast etc) before buying one as it can be a costly mistake. You also need to be specific about what you're fishing for and match your equipment accordingly.
Dynamite
It's not a rod for everyone as you can see. You really need to be strong to cast this rod effectively. If you a serious non-ed angler who targets larger sharks then this should be one of the top choices in my humble opinion. I love mine and use mine for most of my non-ed fishing
Weedeater
thank u 4 ur input, i really got aa better understanding abt the hmg
Hi Navz,
I would strongly advise against buying an HMG rod as a beginner. They do not stand up well to punishment, with the exception of the Assassin Surf HMG series and WAFT Highlander/Technoflex range and chances are you will break it at some point.
Rather spend your money on a decent reel, the likes of a Saltist/Torium and get a standard graphite rod, like the Loomis & Franklin Custom series, which will take punishment in its stride. Much better investment for now.
I'm speaking from experience and have broken a few HMG's, including Reefman's Assassin Med HMG. You learn quickly how brittle HMG can be after breaking two...
