R395 for 1000m sounds cheap and nasty unfortunately... PE is short for Polyethylene, the basic stuff its made of (and most plastic products)
from oceanbluefishing.com.au
"The PE standard of measurement is based on a numbering system known as “gouwâ€, the system that the Japanese originally used to measure the diameter of silk thread. This measurement system has since been applied to monofilament and braided fishing lines. The “PE†stands for Polyethylene, the fibre used to make Dyneema and Spectra braided lines.
The PE rating is a constant measurement, so while two lines advertised as being rated to 50lb may actually test at different breaking strains, two lines with the same PE rating will always be the same diameter. As a very general rule, you can multiply the PE# by 10 to get an approximate breaking strain of a braided line, i.e. PE4 x 10 = 40lb, as it will rarely test below (10xPE#). However, the breaking strain can vary a great deal between different lines of the same diameter. This is especially true in many of the high end braids that use more strands and a tighter weave, resulting in a rounder, smoother finish and higher breaking strain for the same diameter as lines of lesser quality. For instance, YGK Galis Ultra Jig Man X8 in PE5 is rated to 86lb, but Sunline Super PE PE5 is rated to 50lb. Higher end lines are often specialised for either casting or vertical jigging, and usually carry a higher price tag to match their superior finish and higher breaking strain/diameter ratio."
