you started bass fishing...fished from the bank and realised that you need a floatation device to get on the water...so you decide to buy a small boat...but you need a sneaker motor.
be prepared for the all the other costs involved in investing in a sneaker motor...
you can pick up a sneaker motor from around R1000
but then you realise oh oh you need a battery...some of us use 105 amp/hr deltec batteries...but you can use a smaller one...it just doesnt last as long...you also need to make sure it is a deep cycle battery which is designed for this type of application...a standard car battery is designed for high torque startups...anyway i am not gona go into detail...prices vary from around R600 for a small deep cycle battery.
then just when you thought you had budgeted correctly you realise now you have to buy a charger to charge the battery...without going into details...from my almost 8 years i have had my hawkins charger...i am yet to find a better one...i use it to charge everything car batteries...boat batteries...alarm batteries...gate motor batteries you name it...i dont even have a clue what price they go for because i have had mine so long i have never needed to replace it...so the cost...just remember to budget...because they are not cheap....just like any good quality product like fluke...hilti...i buy stuff to last so i spend the extra...the other bonus about hawkins it is manufactured right here in durban..
trolling motors come in various sizes and voltages....12...24...36 volts...that i know of...it wouldnt surprice me if there are not bigger unit available.
just be aware of the voltage when selecting your trolling motor...and make sure it is big enough to push or pull your boat.
the other thing to consider is the distance from the battery to the trolling motor...if your trolling motor is in the front of the boat and the batteries are at the back...make sure you increase the size of the cables to allow for volt drop.
then of course the decision foot control or hand control...foot control is a better way to go go because you have better control while fishing...the problem is the trolling motor is bulky and becomes restricted to one boat...and they are a lot more expensive.
and lastly i would say the most important part of the trolling motor is the volt meter...why because if your battery goes below 9 volts chances are you will be able to charge it but it would have caused damage to the battery which will reduce the life of the battery...
the volt meter i prefer is the one with the red/yellow/green indicator you can watch it when the trolling motor is running it will stay in the green then start going into the yellow...but as soon as it starts going into the red while the trolling motor is running it is a good indication that your battery indicator is clear and will go soon go red.
the battery is the most expensive part of the purchase...because it will need to be replaced every couple of years...so think carefully when purchasing your battery and make sure you invest in a good charger...
please note this is a very basic guide...when selecting a trolling motor for a big bass rig...do your homework...shop around...and if you are not sure contact the supplier of the product.
