Muffin Man
I have been spinning for some time now. I have spun from rocks, beaches, river mouths, sandbanks, harbour walls, mountain ledges and boats. These are a few things that I have been taught and learned along the way which will assist anyone who wishes to catch fish artificially. The fish that I have targetted by casting spinners(spoons) and plugs have mainly been Leervis, Yellowtail and Elf.
One of the biggest lessons I have learnt in my time fishing is that you have to accept that there are people who want to learn and there are people who think they know it all. I have never met anyone who knows it all, the problem with people who think they know it all is, you can't teach them anything.
I have fished with people like this who refuse to accept advice, who eventually make a gat of themselves and never return to that spot again. I am not going to go into different tackle options as that is a personal choice. I spin with an 11ft Exage or Graphcast 4 with Trinidad 14's or 20's, off the boat I use Sustain spinning reels 6000's or a 4000 on 8ft Exages plus a Diawa Monster Mesh. In rivers I down scale my tackle accordingly.
I use Double X high abrasion on my Trinidads and power pro 20, 30 and 50pound on the spinning reels. Your casting ability and the confidence it gives you are the most important requirements for becoming an accomplished spinnerman. Here are a few tips.
SPINNING IN WINDY CONDITIONS:
If you are spinning from a spot where space is limited chances are you going to be standing shoulder to shoulder with other spinnermen. If the wind is blowing from your right to your left you need to cast at an angle into the wind to compensate for the bow in your line pulling the lure to your left. If you cast straight ahead of you the lure will be pulled way left and all the guys to your left will have something to say.
Casting an ABU spinner is the best spinner to throw in windy conditions a flatback or roundback will broach in the wind which can cause an overwind. Narrow plugs cast very well into the wind the problem with retrieving plugs in these conditions is that the plug gets pushed forward by the wind and the waves in choppy conditions which results in loose loops on the spool. If you going to send it with your next cast this is fine as you can cast them out but if you need to make a short cast at a fish it gets tricky as the line can bunch.
When spinning from an elevated spot on hot windy days most of your line will be above the water when you retrieve. Due to this the majority of your line remains dry, the dry line will eventually cut into your finger that you are using to lay the line back onto the spool. Its a good idea to pack a piece of plaster tape in your bag to wrap your finger when this happens. A spray bottle filled with freshwater is also handy to spray the spool every now and then.
If you are standing in the front row spinning and you get an overwind engage the spool and wind in the line over the overwind. Step out the line put your rachet on and put your reel into freespool pull the line off the reel and sort out the overwind. If you don't do this you will possibly loose your spinner (get stuck on bottom) and more importantly when you busy trying to sort out your overwind the line that you pulling off the spool will make a big bow and everyone to your left wont be able to fish. Things will be said.
From the beach it is different if the overwind is not to hectic you can keep your rod tip high and run up the beach to free the line then turn around and wind as fast as you can to take up any additional slack.
I have said it in previous posts regarding plugs that in windy conditions a heavier treble adds drag which prevents the plug from skipping uncontrolably across the surface I use Owner trebles in such cases.
LOOKING FOR FISH:
Most important things here are poloriods and the experience of knowing what you're looking for. When looking for fish it can be anything from as clear as daylight(fish breaking surface) to a different colour water which is moving. From the boat it is more difficult as you dont have much height when looking into the water unless of course you have a flybridge.
From the boat, birds working or hovering over an area are also tell tale signs. If you know that the water is cold outside of Cape Point and the water inside the Bay is warmer it sometimes pays to find the point where the cold water meets the warm water. Fish swim lines inside of the Bay I have often seen fish swim to the temp line go down and pop up in the other direction back into the warmer water now on a different line.
None of this is rocket science it can be worked out pretty easily in my opinion the more you fish the easier it gets. Keeping records has also helped me a great deal. In rivers Leerfish move with the tides so get a starting point close to the mouth on lowtide then move up the river with the tide once things have gone quiet where you've started. I will continue this post tonight at home and please understand that I don't know everything I am just sharing my experiences. Till Later.Cheers Paul (MM)
LOOKING FOR FISH:
