The real difference between HMC and HMG
Weedeater
[color="#006600"]Hooked[/color] wrote:
Where is the pic bru??
Hooked,
You know as well as I do that no-one should attempt that with any HMG blank. I have found out the hard way how brittle HMG is, even a T53 which is supposed to be better than the chinese imports.
I tell you what, I'll test my WAFT HMC as soon as I get it and we can take it from there.
Hooked
As stated before , a waft should be able too do it no probs.I have never dissed a waft rod only stated that they should say which ones are centurys and which are crap.What im trying to accomplish here is to show the guys that HMG is not all its cracked up to be and that we are being fed low price goods at high end prices just cos they say HMG.And I did warn the okes to read their manuals before trying this.Even if an HMG managed to lift this weight without breaking , doing it more than a few times would result in the rod going " soft ".
Weedeater
Hooked,
Dude, I wasn't having a go at you. The point I'm trying to get across, is the same one you're trying to get across, HMG isn't all that, in fact it can more of a liability than its worth.
Believe me, I am a BIG fan of HMC blanks, I've seen what they can do and there is NO contest. Ask Mag-Man, I was in my element on Saturday after seeing his arsenal.
I also do agree that not every blank that WAFT markets as a Century is HMC, for the price they sell them at, its not possible.
In fact, only the very high end Pirates and some of the older blanks, such as the Crest are HMC.
The only reason I own HMG's is because I can't afford to fork out R6000 for a rod when I can a something with decent pulling power for R3000.
That said, I'm waiting for my HMC to be built.
The most important part of the post, is that guys don't break their HMG's trying to lift stuff the rod can't handle, HMG's by nature are brittle and WILL break if you push them too far.
Hooked
Can supply you a completely built HMC for R2000,00 excluding postage.Rod is rated 6 ounce but will happily throw from 5-8.
Whaler
What does the rod/blank cost that can lift the 7 kilo's, thats the one i'm interested in.
ps.Im waiting for my mate to bring his cable to load the pics! you are right when you say that my rod will go soft after a few lifts.(Moer its HEAVY!!!!)How is the castability of that heavy rod? and the weight?
Hooked
Any off the 6 ounce and upwards rated rods will do it.
You are giving up to easily , go out there and lft 8kg so that I can post a pic of 10kg being lifted............
Whaler
Sorry Bucko!! I like my rod, i'm not going to brake it!!!Would you sell me a Blank? or do you sell ready built rods only?i'm not joking i will buy one to try!
christodeb
@ Hooked
Would you recommend that rod for sliding and casting biggish baits or is there something heavier in the same price region.
Hooked
PM me your cell and we can talk further.Furthest cast i have heard of from the UK okes was something like 260m.And just to rub salt in I have lifted 10kg with the rod....
Hooked
Sounds like a very good deal Hooked. Custom spec'd?
Nope sorry , can deliver blank with guides fitted and no winch or grips.
The okes in the UK tell me that guide placing is one of the most important parts of rod building and they wont let them go without.
Hooked
[color=#006600]christodeb[/color] wrote:
@ Hooked
Actually the cheaper rods seem to be better suited to sliding , go figure.
As for casting bigger baits , watch this space got a little experiment comming yp shortly.
andy1
hooked..andrew here ...you spoke to me last week about those rods...are they about R2000-00 and when can you deliver , i Know you said you were waiting for delivery..you still got my cell no ?
Lucky Tom
hooked tom here please can you tell me the waft musselcracker 420/5 what is it a hmc or hmg i can take it by the tip and pick it up but i have not tried to lift a 10kg yet but it was ok on a 70kg bronzy i wouid lick to see the rod you are talking about many thanks tom could you please phone me 021 9313137
scorpion
420/5 hmg t53, i think you have one of the locally manufactured blanks and i would not try lift 7.5kg with a t53 blank. the waft blanks you can deadlift with is the iron feather range, pirate series, g5, kompressor, carbon metal series the are hmc rods
