THE OFFICIAL ACE-CRAFT FAN PAGE
HelloC
Hi Guys,
Just some pics of the progress - decided to overhaul the motors completely as well, so that delayed me a bit...signage completed though....::S
BFC
HelloC wrote:
Hi Guys,
Looks very nice , now you just need a boot stripe above the Spray rail to finish off and keep authentic.
HelloC
Hi BFC - you are right, thought of spraying it on , but a bit nervous to do so, maybe do it with a sticker instead
BFC
Here is another very scarce AceCraft and something for the real nostalgics.
the 10ft Mini SeaGlyder Spearo boat.
thika
Hello C,
4 things:
Coolest marlin with built in chicks on the planet!
The break section of the trailer looks a bit too light gauge
The handle on the anchor drum is too short to crank with...it is going to be a 2 man operation to get the rope laid and the anchor back up at sea...I have ideas to improve
the marlin should have been 3X bigger!!!
Your boat is beautiful
:wfish
thika
Vaderland BFC,
WHERE do you pluk out these old gems from?..not even talking about that collector Alpha Romeo! :fbash:fbash
Please please won't you post all those Ace pics that you had on Boatfishing last week....time to ruk all the wannabee Infidels in the bek again I reckon!
See BJ did a life threatening launch at Swaardanna in that other Cortina fanpage....we have worse swell drifting in light Northwester here catching Hotnotsvis!
LOL Bennie.....you need Cape spray China!
HelloC
Thank you all for all the compliments....I have to get her to the water soon, as I am VERY gatvol of just work and no play !:hyst:
Dooma
Hi guys.
Well, I took all your advice a couple of months ago and my project is slowly coming together, after purchasing the 15'6, I had the deck lifted, stringers and bulkheads were in perfect condition, put extra buoyancy to conform to new regs when they are gazzeted, put live well, put power steering, and hung two 50's on the back, still got other bits and pieces to do but getting there slowly, time and money as usual.
Question, I took it to the dam to do first test, all worked superbly well except for one thing, I have a cavitation problem when I turn, she runs beautifully through to full speed at 6000 rpm so props are good. At half speed even, if I try turning, she cavitates, if I increase throttle on outside motor and decrease on inside motor it manages a lot better, similar to turning a cat. What could the possible problem be, I attach a pic of motors being installed, as you can see, trim plate is level with the bottom of the hull.
Many thanks once again for all the advice to this point.^^..
barryfish
would say motors may be mounted a bit high as when you turn the hull would lean, lifting the one motor even higher, thus cavitation? but I'm not a xpert. you can rev to WOT so the props should be good. or do the motors have trims units, perhaps they trimmed to high? try a notch lower down
