[align=left]DRILL PRESS:[/align]
A tall upright machine useful for suddenly snatching flat metal bar
stock out of your hands so that it smacks you in the chest and flings
your beer across the room, denting the freshly-painted project which you
had carefully set in the corner where nothing could get to it.
WIRE WHEEL:
Cleans paint off bolts and then throws them somewhere under the
workbench with the speed of light. Also removes fingerprints and
hard-earned calluses from fingers in about the time it takes you to Say,
"Oh, ****!"
SKILL SAW:
A portable cutting tool used to make studs too short.
PLIERS:
Used to round off bolt heads. Sometimes used in the creation of
blood-blisters.
BELT SANDER:
An electric sanding tool commonly used to convert minor touch-up jobs
into major refinishing jobs.
HACKSAW:
One of a family of cutting tools built on the Ouija board principle...
It transforms human energy into a crooked, unpredictable motion, and the
more you attempt to influence its course, the more dismal your future
becomes.
VISE-GRIPS:
Generally used after pliers to completely round off bolt heads. If
nothing else is available, they can also be used to transfer intense
welding heat to the palm of your hand.
OXYACETYLENE TORCH:
Used almost entirely for lighting various flammable objects in your shop
on fire. Also handy for igniting the grease inside the wheel hub out of
which you want to remove a bearing race..
TABLE SAW:
A large stationary power tool commonly used to launch wood projectiles
for testing wall integrity.
HYDRAULIC FLOOR JACK:
Used for lowering an automobile to the ground after you have installed
your new brake shoes, trapping the jack handle firmly under the bumper.
BAND SAW:
A large stationary power saw primarily used by most shops to cut good
aluminum sheet into smaller pieces that more easily fit into the trash
can after you cut on the inside of the line instead of the outside edge.
TWO-TON ENGINE HOIST:
A tool for testing the maximum tensile strength of everything you forgot
to disconnect.
PHILLIPS SCREWDRIVER:
Normally used to stab the vacuum seals under lids or for opening
old-style paper-and-tin oil cans and splashing oil on your shirt; but
can also be used, as the name implies, to strip out Phillips screw
heads.
STRAIGHT SCREWDRIVER:
A tool for opening paint cans. Sometimes used to convert common slotted
screws into non-removable screws and butchering your palms.
PRY BAR:
A tool used to crumple the metal surrounding that clip or bracket you
needed to remove in order to replace a 50 cent part.
HOSE CUTTER:
A tool used to make hoses too short.
HAMMER:
Originally employed as a weapon of war, the hammer nowadays is used as a
kind of divining rod to locate the most expensive parts adjacent the
object we are trying to hit. Also ferquently used for onlooker attitude adjustement.
UTILITY KNIFE:
Used to open and slice through the contents of cardboard cartons
delivered to your front door; works particularly well on contents such
as seats, vinyl records,liquids in plastic bottles, collector
magazines,refund checks, and rubber or plastic parts. Especially useful
for slicing work clothes, but only while in use..
Son of a B... TOOL:
Any handy tool that you grab and throw across the garage while yelling
"Son of a B" at the top of your lungs. It is also, most often, the
next tool that you will need.
WIRE WHEEL:
"Oh, ****!"
SKILL SAW:
PLIERS:
blood-blisters.
BELT SANDER:
HACKSAW:
becomes.
VISE-GRIPS:
OXYACETYLENE TORCH:
TABLE SAW:
BAND SAW:
to disconnect.
heads.
PRY BAR:
HOSE CUTTER:
HAMMER:
UTILITY KNIFE:
Son of a B... TOOL:
