The Grinder revolution
dswart
So how do you join your main braided line to your braided leader line.
And how do you join the braided leader line to the swivel
Dynamite 2
Yucatan knot for braid mainline to braid leader with bimini knot making a loop in the mainline
Dynamite 2
dswart wrote:
Thanks really do appreciate you guys inputs ...
Any words of advice what to look for / pitfalls?
Best advice i can give from my experience is put on proper rod eys made for a grinder and wind the braid on under even tension, because if it isnt you going to discover the windknot very quickly, or if you have the wrong rod eyes the braid will catch around them and yank em off and dont overfill your reel with braid either
Hope this helps
Dynamite 2 wrote:
hypershark wrote:
@Dynamite ....
What distance do you recon you achieve on you EVO ? How is the action of the rod during the cast?
I have measered on the field that with the Evo and just a 7oz i would average +-165m and the 8oz +-175m.
I tend to throw the kitchen sink in my cast so i felt when i gave the Evo the full beans it felt like it was going to break but surprisingly not. Its a nice action and softish tip. I must also add that i'm 6ft4 and 112kgs and gym 6 days a week, so for most it will be perfect, for me i like a stiffer rod
i have such a gutter mind..... :spite:spite:spite:doh:doh
Dynamite 2
Henning Venter wrote:
Dynamite 2 wrote:
hypershark wrote:
@Dynamite ....
:doh::teas:::uzi;)
ek weet nou nie teveel van grinders nie en leer maar nog, maar hier is my 2cent worth!!
favorite setup: ek vir my n ou purglass 400/3 omgebou met regte grinder oogies en n saragosa 10000. 30lb braid and love the setup.
second setup: p7 from gremlins with saragosa 20000 en 50lb... bit heavy to fish with the whole day....
Dynamite 2 wrote:
hypershark wrote:
@Dynamite ....
:doh::teas:::uzi;)
o ja en ek weeg 120kg en was 6jaar laas in die gym
Dynamite 2
Dynamite 2 wrote:
hypershark wrote:
@Dynamite ....
:doh::teas:::uzi;)
Maar jy kan nog n lood sit daar waar min manne ooit n lood sal kan gooi nie
Spool-Song
dswart wrote:
Spool-Song wrote:
With that said, when you hook  a decent fish on a grinder, its not the best piece of kit to have around, but that doesn't happen very often.
Why would you say is the reason for this?
I find a multiplyer stronger than a grinder (Aerolex 8000) for pulling big fish. My grinder starts to bend and twist and go a bit wobbly under strain. my Daiwa Grandwave 40 multiplyer is solid. I haven't tried the expensive grinders.
The reason for this not happening very often is that I am a K@k fisherman;)
Okuma makes some solid grinders that most people overlook.
I believe its not fashionable enough for the sheep in our country.
Research the salina and raw grinders. You"ll be suprised. At a third of the price of the saragosa n spheros they are best value for money imo.
Biggest advantage to this type of fishing is getting much more distance if you are an average caster.
In strong sidewashes and rips you will still feel the bites on the braid.
Braid is stronger and thinner than mono provided your knots are solid.
More direct n hookups will increase
You can use any rod aslong as the 1st 2 or 3 guides are changed for grinder use
You dont really have to load a rod to its fullest to get leka distance like with a multiplier setup
Casting n fishing in wind is much easier, you still feel the bites no matter how big bow/arc in the line
Basically theres more pros than cons if done properly.
And with any reel or tackle, if looked after and serviced properly n regularly it will last you a long time.
