ja, julle het dit maklik in die stad....LOL
B basslover Senior Member Oct 28, 2010 #22 mooi man!!!Sal bietjie dit op ons website post...eintlik een nodig wat drie visse van so 1KG kan vat.
H Herman Nel Senior Member Oct 29, 2010 #23 Hi guys,was a bit busy the last two evenings so I will take pics of the Basstube mounted to my V-boat floattube over the weekned. Basslover - Wat is julle website adres? PM dit asb vir my... Groete Herman
H Herman Nel Senior Member Nov 4, 2010 #24 Hi guys! As promised here is the BASSTUBE fitted to my V-Boat float tube. The pics explain themselves I think? Regards Herman Attachments g.JPG 39.3 KB · Views: 45
H Herman Nel Senior Member Nov 4, 2010 #26 Ski rope threaded through tube and held in place with simple knots on the outside of the tube... Attachments b.JPG 38.3 KB · Views: 46
H Herman Nel Senior Member Nov 4, 2010 #27 Tag end of ski rope burnt and formed into a sharp point... Attachments c.JPG 35.2 KB · Views: 45
H Herman Nel Senior Member Nov 4, 2010 #28 Thread through plastic D rings already on your float tube... Attachments d.JPG 45.3 KB · Views: 45
H Herman Nel Senior Member Nov 4, 2010 #29 Push the sharp end back into the rope itself... Attachments h.JPG 46.4 KB · Views: 45
H Herman Nel Senior Member Nov 4, 2010 #30 Pull tight for the neatest and strongest knot you can get! Attachments i.JPG 39.5 KB · Views: 45
H Herman Nel Senior Member Nov 4, 2010 #31 The back end where the bass goes in and out... Attachments e.JPG 39.1 KB · Views: 45
H Herman Nel Senior Member Nov 4, 2010 #32 The front end - which way the bass will be facing and your direction of movement... Attachments f.JPG 37.3 KB · Views: 46
H Herman Nel Senior Member Nov 4, 2010 #33 So if you fit one on each side you will be able to transport several fish safely with minimum drag, no need for aeraitors or bilge pumps! Regards Herman
