Tennis Racket String and Carbon Coated Wire
DJP
Here is two products that gives me a lot of confidence when going for the big sharks in rough terrain.
ProKennex tennis racket string, 1.37mm, at R300 for 200m, making a windon it works out R12 for 8m, R1 for a 1m 80lb Dacron... totaly worth the bucks! (But we struggle to get the stuff from local shops so a contact would be handy).
287lb, Black Carbon Coated Steel, 7 Strand, cost R280 for 200m. Really good stuff, probaly overkill but at 1.05 mm it's actually thinner than your leader. Lekker for slides!
John0
Shot DJP! They say a raggie CAN'T bite off that tennis racket string have you experienced this before?
PatrickC
I wanted to buy racket string the other day, R80 for 10m was the cheapest I could find! Was not paying that for a leader!
DJP if you find a relaible source for that string please let me know!
DJP
John0 with regards to raggies I wouldn't say they cant bite trough it, I mean I cut it with normal sciccors, but it's way more abrasion resistant. I have seen it go through raggies teeth without much damage and been dragged through all kinds of stuff without fail...but a month ago I was bitten of 5m up by either the unmentionable on the line or another one.
PatrickC, like I say, chickens teeth, I'm still looking for my next batch.
Dave Batista
@ DJP sometime later in the year I'm gonna order some of that stuff from you. The steal is a great buy. I'll fit that 1.37mm tennis racket string in a 50lb dacron and make a wind-on, boepens had done it with 1.4mm , and there's no way that that will slip.
DJP
Pylstert wrote:
DJP how does that steel knot? Does it Figure 8 OK because that's a really good price for coated steel
I use a flemish for this wire 280lb is a bit rigid to figure 8. But you get smaller diameters so sure that will knot.
What I do use though is the 7*7 strand, 170lb, it knots like mono, and is very limp so gives plenty of movement to the bait in the water. It is a bit more expensive, R480 for 200m. But for bite traces ect. it's tops.
DJP
Lol I dont sell the stuff, just shop around for better products at a good price. I use 80lb suffix dacron the green one, works easy enough, but if you can fit it into 50lb by all means.
DJP
Just another thing to add, some tennis racket strings have flash worked into them, I've heard Hammers love it so rather get a neutral colour if you have a choice. The more expensive types are also hollow, not something you want.
psion
Gus
Late joining this I know but, I make 6-9 m tennis gut windon's with 1 m trace at the end. I join the trace and tennis window with a swivel an crimped knot. You could take a chance and was a kick arse snap. I have some that are rated at 80 kg's. Biggest fish caught on this type of rig is only 60kgs, but it all held up.
I bought most of the stuff off ebay.
cost worked out as follows:
Netural tennis gut 6 metres R1:50 metre =  R9:00
1 metre 80lb Draycon                             = R 1:20
Heat shrink, Glue and cotton                 = R 40c
Total cost R10-60.
1 m steel trace (0.80mm)                       = R 1:40
Just be careful that you buy decent stuff as there is some rubbish on ebay.
I have also made 6m 80 pound windons that work out at  just under R8:00 each
cheers
Ninja-Nic
Brilliant idea indeed. Did some googling and managed to find these sites:
http://tennisshop.co.za/go/strings.html
not sure where they are though, but they seem to have a variety of strings
http://princetennis.co.za/products/strings/
Direct Leisure Golf (Pty) Ltd
Plascon Building, 14 Union Street  T: +27 11 861 6900
http://www.zomacsports.co.za/
http://www.jitsports.co.za/tennis/string.html            021 825 6222   info@jitsports.co.za
Also take a look at Bidorbuy -search term "tennis racquet string" - plenty listings
Hope this helps guys...
