I was replacing leaders on my working edible reels, using the Tony Jones Leader knot. (a smart knot, you should try it!!)
Following my leader replacements I prompted myself to open the said reels to check for grime etc....whereupon I found one of my reels had a "Loose" screw on the gearbox cover plate, which was subsequently rectified.
Removing working line from the reel is also vital, as at times it becomes scarred from the bricks.
Lol....Heres another one - from a reel I purchased some time back and never knew what was 'below' I removed some 300 mtrs of white .50mm K.F. from my Trini 50 to replace to another reel, when I arrived at another unknown nylon (joined with a Uni knot)....continued to un-spool this k@k and found a third type/brand of nylon (Dbblx ??)
Ok....so all the rubbish removed, spool pin pulled and stored, and proceeded to re-load the Trini with 1200mtrs/ 50lb Berkley Whipass. Waiting now for the .58 Alpha.
Yip so just goes to show....know your tackle, do your homework before, and dont shoot the messenger.
:fishn
P.S. - waiting for the middle moon!
:fishn
