Swivel Ball Bear Snap
Ever been let down by one of these?
Tempted to try it this season for quick spinner / popper swaps. Solder points on the rings are my concern...
What are you fishing for? There are 2 or 3 quickclip designs that are strong enough for me, with a power swivel at the other end of the leader, and that one in the picture of yours looks stronger! I'm not pulling big tunas or billfish though, just hoping for some tail, leeries and whatever small thunnus swims past the rocks.
I made up some quickclips with 1.6mm stainless wire that were plenty strong, as per a tutorial by enigma on here in the freshwater section somewhere, with the swivel on the clip but I reckon they would work better for attaching trolling leader/lure rigs and I think the profile is too large at the lure end for just spinning and affects swim. But it is just a feeling, I wonder about the effect of just a clip, which I use, but reckon it is within reason as I've gotten most of my decent fish like that. I don't really question the strength of the setup as my mainline will go at a chaff long before the clip or swivel gives.
Regarding the soldering, I would reckon it is done for the task and would be fine? It looks the same to me as solders on solid rings used in jigging or slides where big fish are landed...but hopefully someone really knowledgeable will chime in.
Limpopoking
I once lost a prize Couta at the boat side. I was busy contemplating how I was going to get the beast aboard and while strategising, I watched in horror as the fish chomped down a few times on my 150lb Halco trace and the snap hook simply opened up and the fish swam slowly away.
I vowed never to use snaps again.
willo
I have lost a few very good fish due to clip fallers in the past and swore that I would never use one again .
Technology has since improved and there are some awesome clips out there now - super tiny and super strong .
Depending what target species I'm chasing , I will either use a power swivel to a quality owner split swivel . A quality egg clip made by decoy and add a power swivel to it if I'm doing a lot of spinning or if I'm only working stick baits / poppers just use the clip .
The very best clips I've used are made by sampo , but they are pricey at $25 for two , it starts getting very expensive when u snag up and u loose the lure and clip together .
willo
The decoy egg clip rated at 150 lb , I haven't opened one yet .
Very informative input guys - thanks very much!
I do land-based spinning for the usual inshore suspects and your answers have definitely help guide my thinking.
Regards, LL
The solder points on the rings won't be the problem. The same technique is used on the bigger 500-1000lbs Bearing swivels used in Heavy Tackle Big Game
Clips are only at threat of being pulled open if the lure hooks onto the link at the top and not while it is in the bend it won't pull open.
Limpopoking
Incidendly LL, those rings aren't soldered, they are fuse welded so much stronger.
I prefer to work with top quality split rings instead (like Owner). Just have a decent pair of split ring pliers on your belt and its so easy to change lures. Leader onto ball swivel onto s/ring onto lure.
