Thanks for the info Enigma. Will go and check our Hobby shops in PE
In these rigs I used 8mm for the hook ring and 4mm to keep the longer tag ends of the figure 8 in place (left them a bit long to ensure that the 400lbs can pull tight and not slip) Never, ever had a Figure 8 pull open on me with cable or nylon.
You know how to rub salt into my open wounds now dont you !! Adding fuel to an already out of control fire here you are!!Is that a spotty in your new Avatar?
How big is it.
Just to make you a bit greener. Got me plenty 18/0 Tuna Circles when I was in Richards Bay and myself and Trophy got some boxes of 100 Mustad Tuna Circles on the way from USA 12/0-18/0
Count me in as well. Need some of those goodiesWell in that case put me down for a little of everything Enigma. Gotta get my traces and what not sorted asap..
Scouts motto - BE PREPARED - seems fitting not so..
