Sustain 8000FE
Richard M
Any of you have experience with this reel. I bought myself and early Xmas gift and want to pair it up with my Trevala to do a bit of vertical jigging. Have not had a chance to use it. Will have to wait until end Jan, but has anyone used one of these reels before? Does it have the stopping power? The data sheet says it has 29 lbs of braking power, which is a lot.
Richard M
I recently had my reels and power tools stolen after some undesirable broke into my garage. The sustain was an upgrade from an old polikansky which the insurance paid out for. They arranged for Angling Africa in Pretoria to replace all my stuff, so I am not sure if I got the best price. (I just paid in the difference between the replacement price for the polikansky and the new sustain). I think it was about R2 400 (total)
G
Guest
Guest
Hello Guys
I have two of them in the 4000 size that i use for plugging for leeries off of my kayak. Great reels. I am also experimenting with Carbontex washers in them and so far it seems to make a difference. The strange thing with spinnng reels is that the standard drag tends to leak a little. Since I have changed i have noticed that the is more solid and only gives line when it is meant to. I have these reels paired with a 20-50lbs Trevala and a TFO 7ft heavy action spinning rod and they compliment both rods very well. The Trevala series are great for plugging as they are light in weight but have good backbone when you put a bend in the rod.
I went for the Sustain in 4000 series over the Stella 4000 as i could not see that the performance of the two reels could justify the huge price difference given the size of the reels and the performance that one demands of smaller reels. I am sure that when one starts to target bigger species that need to be stopped that the Stella would come into its own. If you are going to be jigging regularly the Stella may end up being better value in the long run ie the cost divided by the number of times that you use it before the reel packs up.
As you can see there is much to consider and with the quality of fish that you are able to target vertical jigging I woud tend towards something that can handle the once in a lifetime fish. Recently there have been a number of top anglers stripped on the best tackle as seen on some of the fishing programs. I would not like to be on that end on the hiding if i could at all prevent it.
My verdict: If you not going to fish very often - go Sustain. if you going to fish regularly and in areas with trophy fish try to get the best that you are able to.
Good Luck
Anton
FREE THE FIGHTER
Haakies, you are right in the money !!!
I have a Sustain 8000 on a MH Trevalla. Spooled it with 50lb YGT. Was using it to drop shot  mainly, however on recent trip to TZ I had my daughter on the boat who is 14 .... so put on a small 100g jig and had a drop for her in deep water , got a fish on and  quickly handed her the rod. Big mistake - a good dogtooth had gulped it then took off - she gave up quickly and gave rod back to me -  I reckon I almost put the drag to max - had to straight stick at times to avoid the rod breaking. Had the fish on for 45 minutes before hook pulled. My point is the drag was tested to the hilt and I have to say I was disappointed - it wasnt very smooth - maybe putting  carbontex washers in it will help.   My point is as we always hear - if you can afford the extra cash for the Stella it IS justified - in these types of situations you will be glad you did !!!  But still a nice reel which will do the job in other situations. Will still use mine in shallower water.
