Strategy for PE harbour wall??
The Boatman
So I am sitting here in the middle of the desert and are on sealine nearly 24/7.:SSS
Besides counting down the seconds till I go home in Oct, I 've been reading up on tactics and everything available regarding PE and its fishing spots. So I came up with this MASTER plan......lol (this is where u guys come in)!!!!
Never fished the harbour wall before but got some tips and ideas through sealine search function....isnt this site amazing??::slr::
So the plan is to slowly troll a couple baits and lures up and down the harbour wall. ::jdskiLive bait would be my first choice. Circle hook through upper lip and weighted down with a sinker on elastic band on the leader.
Turn around at the harbour mouth, vary the speed a bit and repeat back towards the supertubes. If nothing takes on that change to deep diving lures (Halco's/Rapalas) or maybe some soft squids and vary the speed some more. I'll keep doing this untill I run out of ideas, lures or fuel....lol^^..
So where do you guys come in? Well any input on the above ideas will be appreciated and secondly anybody want to join me on this crazy venture is more than welcome!!
Arrie D
Hi apn
We have caught plenty of fish at PE harbour wall in the early 90's. We would go with my boets 4.5m rubber duck - loaded with light tackle and trolling rods. Plenty oF Leeries and the odd yellow tail.
First you get some live bait - either at the channel marker or at the bell buoy or at the coke tin off Kings Beach.
Had a big bin tied down in the nose of the duck for the live bait.
Then we run to the wall ( after a SW wind ). Start on the inside off the wall - 20m in - and troll the mackies / elf very slow. No sinker. We used to put a treble through the skin ontop of the head. You just feel the line go tight - keep your drag very loose with your thumb on it. As soon as you feel the pressure you release. Give the fish good time to swallow. Count to 20 and just start applying pressure.
We fished baitcasters and 6ft rods with 10 - 20lb line. My biggest Leerie at the wall was 17.5 kg and biggest Yellow Tail - 5 kg.
Arrie D
Work your way from inside the wall around the point towards Kings beach - ( the Fence - surfing spot )
You can also work the area from the Harbour tower towards 'Deal party' way - if the sea is a but up on the outside.
But again very slow !
The Boatman
Hi Arrie
Just want to make sure. You saying I should start inside the harbour. Are we allowed to slow troll inside the harbour wall?
I went out with a charter couple of weeks ago and as we left the harbour there were a few small boats fishing in the harbour mouth. The skipper told me fishing was not allowed inside the harbour or the mouth to the harbour.
Not sure if this is the case.
Arrie D
You are not allowed to - but as long as no tugs or boats are entering or exit the harbour they dont mind that much - Well that was 10 years ago !Things might have changed.
Most fish we caught was coming out the harbour on the outside point.
