Step up/down leaders
Hey guys,
Some advice on how to use a step up leader,wat are the advantages and disadvantages? Which knots do you join with? Any further info and diagrams will be appreciated..
Thanks gents..
Master, not sure whether I'm on the same wavelength as you are here bru, but what I know about stepdown/up leaders is this. They were "invented" by some lazy overseas okes who didn't like replacing their guide-eyes when punting a big knot through them - and lets face it, a double fig 8 in 1.2mm leader can be a size knot. So what they decided to do was to size "down" with the leader - the immediate leader coming from the mainline was only slightly bigger in diam than the mainline, this piece of leader ended outside the last guide eye (ie part of the drop). Then they would attach the normal leader ("size-up" again) to this piece which forms the rest of the drop. This way they wouldn't damage the eyes of the rod, since the big leader wouldn't travel through the eyes of the rod! It's doff if you ask me, just introduces extra things that can fail.
Just put on S16 eyes, problem solved; and if all else fails, just throw harder!!
Lol poly..clickity..clickity..clack..
@reefman..you got the idea off what i was trying to say..was toying with the idea recently after reading noweeds article on the poormans gt..it would be comforting to know that the last 2meters off your leader is 1.2mm or thicker when fishing the bricks..
KLIPVIS
I dont think the knot will be smaller tying .55 to 1,2mm than tying .80 to 1,2mm , the reason why guys do it is because it gives you a much stronger knot tying .55 to 1mm to 1,2mm or thicker , the WP guys down here prefer doubling up ie .50 or .55 to 1mm to 1,2mm and up.The above applies especialy when using the fig 8 back to back.
The thinner line tends to cut the thicker line whenunder huge pressure like on the reefs with a mal spottie in the front.
Noweeds
The reason for the step down leader is to fit the knot onto your reel...i like to use 1.5 - 1.8mm leaders on the reefs but the knots are too big to reel onto your spool. Therefore i use 50cm of 1mm onto the 1.5mm and that then reels onto the spool!!
Why don't you just use braid for a leader, much smaller knot or no knot if you use hollow like I do or use hollow as a "between" if you really want fluro?
"Hollow", "between"...??? Was is das?  Poly please explain to us Kippies what you're talking about here...
The big problem off using braid is its abrasion resistance to bricks..when braid is under pressure all it needs is a slight nick against it to give way..so its prob the worst to use on the ledges..
Polychaete
Now you asking trade secrets......
Look for "wind on leaders"    Basically if you use hollow braid, you can attach it to mono without knots.   Its a bit scary in the beginning but you get used to it.   So in theory you can take your main line, attach 1 & 1/2 mt hollow braid, without knot, then attach leader material to braid, without knot?
I use hollow braid straight as leader and have been very happy with that but am very certain that this can work if you want fluro.
No mote clickety clickety etc. :D
Noweeds
I am making wind on leaders with 1.4 mono and a braided loop....will be giving it a try with some serious fish this season.. ;)
A chappie in my club has a dedicated swim bait set up off a 365/7 with a shimano tyranos and a monster amount off braid on it..he uses wind on leaders with great success...but the mitigating reason for me not using it is cost..unless weedie will teach me how to make them?
Noweeds
Robbie has just set himself up with a Tyranos and a 350/7.........which we will be filling with braid and then getting moered by submarines!!!
Pylstert
HI MA
Braid loops are relatively easy to make, used a lot in flyfishing. The trick is to make a loop that you pull straight through and then thread onto your line, you then use 2 nail knots/snoods to tie the loop onto the mono. You don't have to do this as the braid grips the thicker line on the chinese finger principal, but it gives you a bit of peace of mind. It's supposed to be 100% breaking strain and no knots that bang through your eyes. It probably all sounds greek/chinese. If I get a chance I will attempt a picture.......If you are simply joining hollow braid to mono then you just thread the mono into the braid for a long while and tie a nail knot on the braid. I have never had one slip off very slippery floating fly line.
Pylstert
Pylstert
Hi Assassin/Bazooka:D
Here's a pic of how I make loops. Whiplash or Kingfisher braid won't work as it is not hollow and not nearly thick enough to take a 1.4mm leader! You have to use something like Dacron 130lbs-200lbs or perhaps there is something better now. One of the tricks to make it easier is to cut your piece of braid (about 30cm). Stick a thick needle in the end and melt the tips together (just the very tips). Repeat on other side. This stops it from fraying while you are looping or threading. If you are simply going to join mono to braid then you are obviously only going to have one tip to burn.
You can buy over the counter loops but they are not pulled through and a yank in the wrong direction can see the loop pull loose. This wont happen with such a loop.
Hope you can make out what to do from my attempt at a technical drawing.
Pylstert
Polychaete
Pylstert
There's a better way to make the loop, so it can never pull apart, I just don't know how to draw it. Will try tomorrow morning. MY camera just got stolen otherwise i could do it with a photo.
AFTERTHOUGHT
Maybe Im not reading your diagram correctly, will look later:?  its 02h00 in the morning.
Polychaete
You require a special open eye needle for this, but can improvise as shown.
I had to use my phone, so apologize for poor quality of pics.  What a “gesukkel” this was…LOL
From Top left
  • Insert needle with strong thread in to hollow towards main line leaving ±15cm tag end.[/*]
  • Put main line in to thread loop.[/*]
  • Pull back on thread to feed line and needle through hollow, to make appropriate size loop with main line doubled on itself.[/*]
  • Now pull tag end forward to make main line single layer and adjust loop size.[/*]
  • Again insert needle in to hollow, with tag end to finish off, and cut tag as required.[/*]
  • You end with perfect loop, that can not pull apart, and with no visible signs of knot.
Pylstert
Hi Polychaete,
Thanks a lot, I have seen this method, it's great for doing a loop at the end of braid. You need a 25inch screen to see your cell phone pics lol!!! The method I showed I prefer when I want to make a loop onto a flyline. Yours is best certainly to make a loop in a braid leader or the likes.
Pylstert
