Spro Frogs
sealady
Also have the same problem guys, but not much of a mission to get the water out. My hookup is BAD but considering what LGF said wait to feel the bite and then strike.
Speedworm
ive caught allot on it. obv you get excited when the bass hits the frog which causes most ppl to strike too soon. just wait a little bit then strike hard. at first i also used to strike too soon but then i caught on and my hookup ratio improved allot. and with regards to the frogs filling up with water it can be good and bad depending on the conditions. when it has some water in it you can cast further and it seems to have better action but ye all you do is give it a squeeze and the water is gone. i even had a bass hit my spro frog so hard once that when i got i landed him the frog was down his throat and when i took it out it was inside out
Jovis
Weasel wrote:
Jovis daai is babetjies lol lol. Awesome vis matter!!!!! Is dit die dam by vroulief se ouers????
Nope, dit was by Laughting Waters. In retrospek moet ek noem dat die vis van '2.85kg' waarskynlik kleiner was. Het later ontdek dat die skaal wat ons daai dag daar gehad het bietjie dodgy was..
