Spoons for sardines
Gatiepie2
1. What are the best hooks nto attach to the Shepie bomber spoon?
2. What is the best way to attach them?
Gatiepie2
Must-Byte
I have the same problem. On many spoons you can't get a split ring on, I have seen the hooks then attched with piano wire but my fine motor skills just cant twist it neatly enough any tips for that guys?
khan
give me a call i will help you out!!!
Are you coming down for this run??
Gatiepie2
send me a mail i will guide you through what and how.
rockhustler@telkomsa.net
Homie
My 2c,
PRACTICE !!!
Use piano wire, and after a heck of a lot of practice (and a LOT of painful and pricked fingers) you can actually make a ring with it.
I use a decent 4'o hook or 2 of them shank to shank, tied with the points facing each other.
OR,
Just take Khan up on his offer !
JJ Pienaar
With sard run's U CAN NOT COMPROMIZE using substandard terminal tackle, the first hook i'l look at to use on my own spoon's are Gamagatsuz Ocky'z 6/0, 8/0... As u never knw what u gona make tight with u must alway's make use of the best..
If u want wire on your spoon's, wire ring's...
drop them off with me at the shop suply the wire and i'l make them up for u in my lunch break...
Must-Byte
Gatiepie2
Im down at St Michaels from the 16th to the 23rd of June then possibly again from about the  3rd of July till round about the 8th::S but Ill be fishing up and down the coast
ZANAIDOR
I replace all treble hooks with Assist single hooks easy to change and available at Kingfisher.
Regards
Rajen
NB. picked this tip up from Reefmans lure fishing tutorial.
