Spod rod advice
toli
Hi all
help asb.
Im looking for a spod rod(or any other 2 piece rod that will do the trick), it's a struggle to find rods in SA.
I will pair it with an alivio reel (the reel i already have)
https://www.decathlon.co.uk/alivio-10000-fa-id_8210920.html
And I will use these spombs I also already have
http://www.henkor.co.za/henkor/henkor-bait-rocket.php
Now I only need the rod - I have no idea what to look for or even where to look for.
and was thinking to use 20lbs 0.19 braid
http://www.alloutangling.co.za/braid-grinder-pe15-4x-300m-20lb
and a leader of 0.62mm 120lbs to take to power of the cast
http://www.alloutangling.co.za/braid-boss-leader-8x-120lb062mm50m
Can the guys using a spod please assist, will the line,reel and spombs mentioned be able to do 100m and what rod should i look to use ?
Any and all suggestions will be appreciated as i'm in the dark with this currently
toli
Thank Boss, I owe you for this one.
I arranged with him to hold it for me until we can meet next week.
toli
He send me a list with all the tackle he is selling.
everything is proper tackle, fox,nash,chub,Gardner...
I'm taking 3 fox rods of him as well.
toli wrote:
Hi all
help asb.
See if you can find a Tribal LC or Suppressa 13' 3.75lbs and you'll cast it 160m or get a Technium 13' use the heavy tip and cast the 150gr+ spod to 140m
toli
Thank you Enigma.
The technium is widely available and affordable, I will keep this in mind if the sonik spod rod is not satisfactory.
