Spinning
mangoboi
Hi All
Cought my first sea spinning outfit.
I have 30lb braid on the real.
Bought a few lures to test down in Ovongo during the Sardine run.
Needing some advice as to how to rig these.
Leader ? Knots onto braid etc.
I have 38 and 50lb leader. How long should the leader be for the spinning rig ?
Some advice would be aswesome guys, i have been looking around the forums and i a super keen to learn.
What do you think of these, my first 3 lures, all 3oz
Ready for the sardine run
Any help and advice would be awesome guys. Thanks
Mango
Add 2 otheres to your arsenal Clone black and silver and sea sprat iron candy both 3 oz.
Leader do you want to cast it off the reel ot is it going to be mono on front .
If a braid leader is used look at the bobsands knot if mono is used look a the spyker knot
mangoboi
Thanks bud i'll see if i can fond those lures.
I have 30lb braid on the reel, the leaders i have are mono.
Will check for the bobsands knot, how long should the leader be ?
mangoboi
Cracker 48 wrote:
Hey Mango
Any tips on spinning in Mombassa ? I am off there on tthe 29th June
Lol, no idea dude. i posted this as it will be my first try at spinning in the sea. Sure some guys here will have some advice for you
G
Guest
Guest
just change the trebble hooks on those lures with two back-to-back singles
mangoboi
Vades wrote:
What rod and reel will you be using?
Will you be fishing in foul (rocky) areas, or on sand?
Howsit Vades
I have been lucky enough to organize a Shimano Exage and a Shimano Stradic 6000 for less than cost price through a friend who has a charter business. Will post pics once i get them, cannot wait.
mangoboi
Hi Mango
I cant seem to find pics of the lures you mentioned, can you post a link or a pic for me please bud
mangoboi
Thanks bud, i am going to change the trebles for J hooks.
Read a post here and see it helps for not getting hooked on the rocks and stuff. Thanks for the advice
die spook
Hallou Mango
Jou "leader" moet nie te lank wees nie (so 50cm tot 1 meter as moontlik) anders gaan dit jou gooi afstand belemmer. Die knoop wat jou vleglyn (braid) en "leader" moet glad nie met die gooislag in aanraking met die ogies kom nie en moet dus weg van die boonste ogie wees as jy ingooi.
Stywe lyne!
Spook
mangoboi
die spook wrote:
Hallou Mango
Stywe lyne!
Spook
Tx Spook for the clarity.
All the other posts i read said that the leader should be a metre longer than the rod so you dont burn your fingers on the braid casting. Is the general lenght 50cm to 1M ?
I'm confused
Stapies
Hello Mangoboi,
Where do I start. I had the same conversation with several people in the past. The general feeling people shared varied the same as now. Most people prefer the knot of the leader NOT to enter the reel as this may hook up with the braid as you cast and then cause wind knots that you will not get out easily. The braid does not hurt your fingers much when you cast especially not if it is thick like the 30lb braid you are using.
The length of the leader is up to you but the longer you make it the more is influences the casting distance, but then if it is too short it defeats the purpose of using a leader. My leader length normally is normally dependent on the length of my rod I use. When I cast the knot sits about 30cm above my reel on a 7ft and on a 10 ft about half way the length of the rod from the reel.
The type of knot you must choose as there is many. Excuse my spelling of the names of these knots but you can use the union knot, bermini twist with a union knot or burmini twist with a wind on leader(strongest in my opinion) or albreght not... I always try to keep the knots small so it doesnt catch on my tip guide when casting.
Here is a link on different knots...
http://www.animatedknots.com/indexfishing.php
Lures I would take lots more spoons(iron candy is deadly) and a wider variety of plugs(chisel nose and different sizes also) and then some dropshots.
mangoboi
Stapies wrote:
Hello Mangoboi,
Thanks for the info boet.
i have a 10ft rod, so i'll go for what you suggested. Half way between the reel and tip for the leader.
I got me an iron candy already.
Going to change my trebble hooks on the other lures to the J hooks aswell.
going to have to practice some of the knots this weekend.
Thanks again bud
mangoboi
cool can you PM me prices, shipping etc cause i am in JHB.
Would look at the 3oz black and silver like you suggested
mangoboi
Back again
So, now that i have got the lures, knots and hooks all sorted i need me some spinning kit.
My mate can get me the
Rod
Shimano Aerocast 10ft @ R2050
Reel
Shimano Stradic 6000 @ R2181
is this a good price ?
Being my first sea spinning outfit not sure i am willing to part with my Rands for those. Although i am in 2 minds and i can only see great write ups on the 2 from the Shimano tackle sluts on th forum and i do understand that it will be a lifetime investment. Shimano is great gear and lasts, i have so old school Shimano's that i have had since i was a kid.
I wanted to see what you all thought and possibly give me some more direction and possibly give me some more options.
Can get the Berkley Air @ R1300.
What about the Daiwa's ? What options are there ? they seem better priced.
Guys thanks so much for all the advice on the forum. Mucha ppreciated
