no sense in this casting as it def make a diff with weight / leaders / bait on the hook sorry if i sound sour or misrable but a fact is a fact
Off a beach very close call.
Off of rocks the Half Pendulum.
Hi, it is precisely that I intend to fish there for 3 months that I have done research and deliberately stand knee depth to cast a 14ft r0d. The problem I faced was clip opening due to slack line in the swing (due to poor footing) and unable to take a step in the water to powercast (due to the vicosity of moving lower body in water).Alfred we seldom if ever cast off the ground.
As I mentioned many anglers will wade to at least knee and waist deep and often they will wade through a neck deep trough to cast in waist deep water off of a Sandbank or reef out in the water.
Using the SA cast with a drop of 1.8-2.5m is completely possible in waist deep water.
Then fishing from the rocks and or beach we clip our bait's, especially bulky baits like a half a sardine with squid so that the set-up is more aerodynamic and will fly better.
The clipping method we use will see the rig separating every time the line is placed on the ground so the aerialised version of the cast is much more convenient.
In fact if you cam fishing here for 3 months at all venues along our coast I can almost guarantee you will not see a single cast made off the ground and definitely not a single Pendulum cast.
It'll be an overhead thump or the SA cast and nothing else.
