Tell me something, when you use a snell knot, doesn't it unravel when hook is just floating around.Wanted to try it the other day, but lost confidence on closer inspection.
The only time it doesn't work to well is when using uncoated wire. To solve this problem you can add a bit of heatshrink to the shank of the hook, this will help stop the slippage.
