Snatching drag on Diawa 600h
tkei
I have just serviced one of my old diawa 600h reels (followed Alantanis' tutorial on the 450h from serviceing section). They dont have the best drags int he world but its now snatching badly. The washers are well greased etc but the snatch is bad. I re stripped it and checked the schematic to see i had it all put together proiperly and it is, but stillt he same problem.
I have used proper diawa drag washers. Alantani says use penn drag washers but cant get them in El.
Any ideas?
FLUKE
Have you used the Kingfisher drag washer grease(oil, normal grease or leaving them dry Does Not Work!) on the washers and don't forget the little washer under the gear it is just as important as the big ones. Failing that get an old pair of genuine leather shoes or some similar leather and cut yourself some leather drag washers then you'll never look back. Try get leather that is a similar thickness to the original washers.
tkei
Thanks fluke. I didnt grease the washer under the gear. will give that a bash. Ja, used kingfisher drag grease (red one). if that doesnt work, will go for the leather or carbon tec. just dont want to spend a fortune as i have 2 600's and 6 450's and 1 50 that need redoing and i use them as spare trolling reels when I am bottomfishing but ned a game stick in case. will let you know how i go.
appreciate the help
tkei
Fluke, I greased the bottom washer and its a lot better but still snatches a bit. going to do the leather thing next year (out of time this year) and or do the carbontec.
Thanks for the help.
FLUKE
tkei, is the label or the grease red? The Red grease is for the gears etc. and then you get a white grease that is for the drag washers but I think the label is red. The actual grease must be white. Those Daiwas are sometimes difficult to get right.
tkei
Fluke, The grease is red. Bilmoria sold me the red grease as the guy that services the reels there said its the better one. I used to believe they were dry drags until i came on here. I am learbning. I will now go and buy the white grease. Thanks.
Regards
Adam
FLUKE
tkei, I'm sure you will notice a difference with the white grease. You can be fairly generous with the grease on most of those Daiwas.
