Sliding gaff, Myth or Reality?
Maasbanker
I was fortunate enough to fish the Southern Cape region, between Mossel Bay and Fransmanshoek. Unfortunately you have to do a lot of rock hoping at the "Saal" in order to land the big fish as well as to release it. Then a friend of mine mentioned that I should get a sliding gaff, that clips on the main line and "slides" down into the fish's mouth/body. In that way making it easier to land the fish.
I looked and asked everybody and nobody has heard about a "sliding" gaff. Does one really get a sliding gaff or was it someones fantasy still to materialise?
Angus
Also called a cliff Gaff, very popular in Australia:
Use to gaff fish from any high point. Attach rope to the top ring. Slide the fishing line into the split ring and lower down line. Hooks will open upon hitting the fish. Pull on rope to set hooks and pull up fish on rope. Hook length 24cm. Well made with stainless steel hooks and chromed head.
Tip: When fish is gaffed loosen drag on reel before pulling up fish.
Maasbanker
Thanks Angus !!!! Atleast I can sleep easier at night knowing that it does exist and I don't have to try and conceptualise it in my dreams any longer ...
Tony Harding
Yep cliff gaffs are very popular with rockhoppers over here......Some of the cliffs I have fished are 60m above the water. I will lift fish to about 6kgs on the rod(M14) and after that you need the gaff.
The 3 prong is the most popular but I have one similar to the second pic Angus put up but mine has 2 prongs, well it did untilI modified it so a third smaller prong sat between the 2 so I could use the 2 big ones as locaters each side of the fish and get the middle prong under the chin. Better on mid size table fish.  This way we have one of each type when we fish the high rocks.
You know your alive when you pull a 20kg fish up the cliffs with one:?
Mako and Wilson are 2 brands if your trying to track them down.
TH
hang bal
More Habib
Ek weet hier in oos london kan jy dit by die tackle shops kry.Ek weet nou nie waar jy dit in Pietermaritzburg gaan kry nie.
