All go's on how big your bait is hey, begin with small quick shakes to get it through the surf, " try read the wave as to not let the big sett's of wave's break over your bait, as it will more than likely wrap your bait up around your main line" once u got your bait behind the breaker's and u cant see it any more try see witch way the curent is pushing a walk 20m up curent and try get to higher ground and change to longer slower shaking strok's for 10min or so... after that every half hour or so i like giving my rod a few shake's for 2min to make sure that bait is down properly....
NB.. U knw if u get a plastik packet wrap't up around your line that fealing it make's , u should get the same fealing if your slide is wrap't up around your main line.... one will never knw if your bait has gone down to your ring, but if the condition's arnt right for sliding rather throw a bait as your hook up rate and landing rate will be much higher...
