good thing I've been forcing myself to throw more big baits this season.2 guys at Natioals in Struis had them fly off the line while shaking their slides down, after reading Enigmas post it seems less of an uncommon occurrence, we took it as a freak coincidence that it happened twice!
I see no reason why there should be less burn-offs caused by this slide versus any other, no reduction in coils, compared to a standard 4 turn slide. I think that bit is all in the head. I get very few burn-offs on normal slides( can count on one hand in the last 3 years) doesn't mean they don't burn you off!
That said they were developed by a legend of SA angling and why would he build and use something if it doesn't work! I would use them even after hearing the stories of them flying off! Just means you should keep your line tighter!
Craig Van der Poll wrote:2 guys at Natioals in Struis had them fly off the line while shaking their slides down, after reading Enigmas post it seems less of an uncommon occurrence, we took it as a freak coincidence that it happened twice!
Monster's Are great , albeit expensive ...
And i do think They should cause Less burnoffs there Craig , seeing that the Little clip IS no Longer There .....
I like em .
Not gettin any fish though , so it doesn't really matter what slide I use .................lol !!
If a fish picks up the bait if the slide is not down at the ring then surely there is chance that the line will get caught in the clip of the slide and there is less chance of that happening on a shakedown slide? Getting caught in the clip will surely cause the line to break off instantaneously?
The burnoff isn't a burnoff it's when the line gets caught between the end of the U in the clip and the clip itself. This jams the line and compresses it causing it to break or compress right through to cut it.
This slide doesn't have the U so the line can't catch in it.
Khan's slides are great I also have a heap of them that I got from Trophy with the bigger #1 Jap power swivel on.
