Normally the objective is to give reports in a positive way,`cos our members need to break away from a hard week and go and fish even if it is just for the outing which is so much needed to clear the mind.But when it comes to this weekend,I tell you straight out that it will be a fishing weekend second to none.
The moon phase is most properly the biggest variable when it comes to fishing the Baan.Last weekend it was full moon spring and the current then is just to strong for the water to warm up.Elf does not like changes in water temperature and without Elf there will not be Kob.Smaller fish like Stumps have no change to swim and feed in the strong current.So most of the catches were made towards Spreeuwalle where the current is not as strong.But this weekend is just the opposite.Very little wind and Saterday might even show some drizzel...ideal conditions!So let us prepare...
ELF:There are big fish around and plenty small ones as well that will attract Kob.Do not use a sliding sinker,but you would need a sinker with the current to keep the bait in the middle water otherwise the birds will get to the bait first.Use fresh bait and only use a spinner once the Elf are in shoals.You need a steel trace,a long,very long strip bait ,then a "skirt" and then attach a 4,0 hook at the bottom.Elf sometimes bite towards the rod,so a sliding sinker will not allow you to feel the take.Or they will nibble like a pecker,so a rod holder will not do..but at times they take the bait with force..be ready as the Elf will be on the feed this weekend.Most of them will be down at the Line,but the shore angler will find them also from the Military slipway and South,there have been takings at the bottom of the mountain next to the Yacht club..and where Elf is,there will be Kob.Make sure the bait is shiny and at times move it to attract attention.
KOB:A steel trace is not prefered,but what can you do with all the Elf around..so you have to "hide" the steel trace.Use a sliding sinker,then swivel,then 500mm trace with a 4,0 sliding hook.Then a short 6" steel trace.Cut a strip of chokka white and well beaten,cut tentacles at the bottom and hook it on the sliding hook.Tie a long fish bait,harders,pilchard,skipjack,steentie,small elf or makreal around the steel trace with meat on the outside and a 6,0 hook at the bottom.Hook the sliding hook with the chokka on at the top of the bait.Change often and keep it fresh to get some smell which Kob needs to find using it`s smelling abilities.
Stump:Use only one prawn with hook through the tail to the mouth.Only tie the tail down,,just no ball of bait and don`t let the hook show.
This weekend I am going to catch fish!Hope to see you around as it is a fishing weekend..and I do not think Spreeuwalle will produce this weekend.So have a great time and God bless!
