Sinkers
DvS-Soutie
Hi all
I have been fishing for years since I was about 4 (no lies)
but shore fishing is something entirely different to boat. One of the problems I am trying to figure out is
Which sinkers are better where. some people I am to believe are dead against grapnel sinkers and some wont go fishing with out it, Why? and if you happen to be against grapnel sinkers what is the alternative.
when I started R&S fishing I saw these sinkers with wire sticking out all over the place. I was rather horrihied at the prices of these rather strange thingy magigures so and only until recently I learnt what the top bent wire is used for but PLEASE correct me if I am wrong its a bait hook and you would hook your hook on it when casting?
I also don't know exactly how to rig this up I can gather that your hook line is shorter than your sinker line be it a sliding or none sliding, (which to I'm clueless on when to use or not)
Could you fellow lovers of the tight line please inform me and any info on this would be greatly appreciated.
Thanks in advance Leon
:fswim ::jdfis
FeedingFrenzy
Hi Leon
Yes the little bent arm is for hooking your hook onto.  Your hook snood will have to be shorter to slightly shorter than the sinker snood to enable the hook snood to be under tension and thereby stay clipped in.
Personally I don't use grip sinkers i.e. with the arms - be they fixed nylon or breakaway steel arms.   If you are sliding then yes, grip sinkers are essential.  I prefer to use them without the arms - and as of late I have acquired stainless steel wire clips from a mail order company in the UK - they look like a genie clip but have a bent arm instead (I'll post pics tomorrow).  This allows me to use whatever sinker I feel like - provided I tie a nylon loop through the sinker eye to clip onto.
My take on not using grip sinkers for surf fishing is this:  if the current is so strong that it washes a standard 4 ounce plus lead out of the sand then you should be fishing somewhere else.  The reason is that fish will be looking for bait fish (in the case of kob and elf) and worms, crustaceans and molluscs that have been washed out (steenbras, stumpnose, galjoen, kob).  A fish wants to expend as little energy as possible to acquire as much as possible.  Therefore they will be waiting where the food comes to them - which is why one fishes on the inside of a snad bar for kob, elf, steenbras etc - the water breaks onto the bar and all organisms that are dislodged was onto the beach side - which is where the deep gully runs.  Often small harders are there feeding on the bait organisms (especially if the gulley is close to the shore) and kob and elf will hunt them here or the fish are just waiting for whatever is dislodged.
Also sometimes on a beach you will notice a pile of stones/red bait pods etc that is triangular shaped (narrow point towards the sea and then broader behind on the beach side).  Fish here - cast out and let the current take your bait - when it stops you know it is where the fish will be - they congregate here waiting for the current to bring food to them.  It is like a mini riptide - where it ends and swirls out is where the fish are.
Robin
DvS-Soutie
Thank you very much that is a great point of view and just the sort of answer I was hoping for.
t(((up((t(((up((t(((up((t(((up((t(((up((
Strepie
FeedingFrenzy wrote:
Hi Leon
Robin
Some interesting points made here. Will try it out. Would you mind sending me the details of that clip.
FeedingFrenzy
Here's a link to a site where you can check them out - I never had a chance to take pics last night (teething daughterbw_l_))
http://www.wsftackle.com/acatalog/gemini_rigclips.shtml
They are such a simple yet ingenious invention.  You tie your line to the eye, your sinker hangs off the teardrop loop and your hook clips on the little arm.  They are almost fail-proof - if you cast flat they sometimes don't unclip - the sinker must drop in and then its a 100% success rate.
They can't be too difficult to make either - I have been contemplating either heavy single strand biting wire or the high tensile steel wire they use for electric fences.
Robin
DvS-Soutie
Yes I too am glad mine is past that. Thanks for the link. I have to agree with you they don't look very difficult to make but a great invention. I will give it a try this Friday, I might differ mine how ever, but will let you know how it goes. :D
subaruseun
@ Feeding frenzy.
great advice... what i recently discovered too was that certain species insist on a free moving bait.
the "sinker must roll", the bait glides past them and they will grab it, light tackle works well when fishing a mini rip, excellent fight.:::S
Sharky2
Great post Feedingfrenzy,very informative and on the money!just one thing,u can buy those clips in most tackle shops,I think it's called a bait clip.I also have a bait clip with floatation on it,it's called the bait carrier.very handy indeed,no need to tie foam around your hook,just attach the bait carrier to your hook,tie your bait and clip it to your sinker.search sealine for bait carrier or see the website www.baitcarriers.co.za
Def-e-nition
Robin
RObin , Pm Sailfish on the Site - He Has Enough time and expertize to make you Hundreds of these clips .
 If i use a flat sinker , i do Not cast one , without one of these on . i am used to clippin my bait , and if the type of bait allows it , these Things Work Like a Charm ..
good advice there on the Eds fishing . I'll still use graps , but the advice is pretty solid .
