single or trebles for tigers?
tuna
some of my spinners are single hooks but most are treble's
what do you okes mostly use
Would you all change it to singles?
What the best hooks and what size hooks
Shot ouens
Dingleberry
Howzit Tuna. I have fished for Tigers only a couple of times and there were no huge ones landed - up mto about 2 1/2 kg. I found the hookup ratio of trebles to be very poor. My mate started trolling flies - Mickey Finn type on Salmon hooks - and we got 90% hookups!
Cpt. Hook
Shot ouens
Hi Tuna,
Singles are better, and you can also use double singles on certain lures like spinners.
For bait fishing use circle hooks for the best results.
FA
dodger
Howzit, all my lures have a final single hook, size 2/0 - 4/0, and sometimes I'll put a trailing single hook as well size 2/0 coz they can bite short, but the last trip the fish taken on Halcos were on th ebelly treble hook, most confusing.
Hooks should be chemically sharpened, for sardine fillets I use bass hooks size 4/0 which have a long enough shank to tie on a nice fillet. Circle hooks also work.
:::S:::S:::S:::S:::S
JDV66
"Tigerwakka" # 5 and # 6 spinner with (sharp) SINGLE
::S
blue42
I've very little/no experience tiger fishing but have a trip booked in October. I've got 2 half-day's booked above the falls with Angle Zambia and hope to bend some lips. Went shopping the other day, got some Effzett spoons (mostly 22g doubles), spinners and a couple Rapalas. Anyway, guy at the tackle shop changed all the spoon and some of the spinner's hooks to Daiichi 6/0's (the red ones). Is that overkill or will they smoke the pipe?
speartackle
We have just come back from Vic Falls.  Caught 3 and lost 2 Tigers all on Rapala with trebles. Lures that performed best were copper / orange coloured ones, they seemed to do better than the blue which caught nothing.
Of the 2 lost one was the first bumb and the second during the aerial display.
Nam-fish
The 6/0 is fine on the effzett's. Make sure to replace the splitrings as well with stronger ones, as they tend to open with big tigers. Also add a small piece of bright red wool (3cm) to the hook eye, if your spoons haven't already got that small red plastic trailor connected to the splitring. Seems to increase the strike-rate considerably for some reason.
FREE THE FIGHTER
Hi Nam -fish
Thanks for this - what make/model of hooks do you use on your Effzetts and make/size split rings - for both the 22gram and 30 grams. I found some hooks the eye is too small to fit onto a descent split ring. Also do you just hang a single off the bottom or also add one to the top split ring ?
Any other info would be much apprecaited - many thanks
Brakdog!
hey bru, yes Diatchii 6/0 with fish tech slpit rings 6 or 7mm in size, try us the double blade effzett spoon in copper or copper silver in the 32 and one size smaller.... upgrade the swivel to a power swivel and use some 40lb trace wire, it doesnt have to be long, around 20 cm should do the trick. I upgrade all my spoons and spinners to a big hook size, even a baby tiger can fit a 6/0 in its mouth. go through the tiger tread and you will see some pics I put up of a recent trip and also some other discussions some of us have had around this very topic. Oh and get some red yoghurt tub lids and use sort of 1 and half cm pieces cut instead of the off the shelf red tags.... see pic how they absolutely shred the harder more durable plastic of one of my spoons.
blue42
Shot for the info guys. I've replaced all swivels with Gamakatsu hyper swivels (100lb and nice and small) and split rings with the flat japanese jobs rated at 70lb. I've also bought a variety of Gamakatsu Soi Ring hooks from 1/0 to 7/0 so I've got plenty spare. Also got some 30lb Not-So-Kinky wire, amazing stuff, knots like nylon with no kinks at all.
speartackle
You're gonna catch !!!!!
Nam-fish
FREE THE FIGHTER wrote:
Hi Nam -fish
I use VMC Siwash 9170 in size 6/0 or 7/0 depending on the spoon size. They are short shanked, wide-gapped with huge eyes, all of which are nice contributes for spoons. Also sharp & strong.
I also use those splitrings with the flattened surfaces, if you know what i mean. Can't remember the brand. they seems stronger than their counterparts thats made out of the  "rounded" wire. hope this make sense
