Shrimp
duckbill
Hi all
Do you think the below lures would work when targeting blacktail and stumpnose in rockpools on exposed reefs? Anyone try this before perhaps? It seems like it could be a lot of fun.
I think baby leeries and grunter in estuaries might show interest in them.
Duckbill
victorius
I'm no Expert but there absolutely no reason why it should not work - I would be keen to try it.
Where are they obtainable in Gauteng ??
Let me know the results when you do try it out - they are very realistic
duckbill
You could order from Ganis:
http://www.ganis.co.za/pi1643/fishing-lures/freshwater-lures/hard-baits/strike-pro-shrimp-50.html
I know of a spot where there are plenty of pools to try this. And I have seen juvenile to pretty large fish in those pools. Should have tried it out a long time ago.
willem wikkel spies
just change the treble's to circle hooks.
when fishing over rocky areas.
j hooks and treb will get stuck.
I think this is the only aspect of fishing where I would fish with circle hooks
Ben REINERS
We have used them with gr8 success in the Mtunzini Amatikhulu estuaries catching Perch & small Kingies & the gurnards love them especiall being slowly fished & hopped off the bottom.
You will never know untill tried.
duckbill
Hi all
Thanks for your responses. I will be able to try this idea (spinning in rockpools) out during my winter vacation a few weeks from now. I will report if I catch anything. I think a clear shrimp would work well on the reef I have in mind, as I have seen tiny little clear shrimpies in the water there.
As for the rivers in the summer months, the mud prawn imitation will be my weapon of choice for grunter and leerie.
Tight lines.
Limpopoking
I reckon they would be like crack for Grunter... I'd like to get some next time I'm in Ganis. Thanks for the heads up.
MichaelK
I bought a few lures through wish and got those prawn lures as a bonus. I gave them to a mate who only fishes in durban harbour and he had success catching grunter on the banks with them.
duckbill
So I got two of those shrimpies. Pink one and a clear one. Which colours worked for you Ben?
Michael did your friend replace the small trebbles with bigger hooks? These hooks on them are tiny.
Ben REINERS
Nice going....also try find the brownish one.
I've found that the clear works well early morning late arvie, in clean water, & the pink during the day.
The brownish one did its job in more murky waters....
Play hop-skip & soft jerks with them off the bottom with intervals.
Vary your retrieve/skips/intervals to find which one suits the feeding fish.
duckbill
Thanks for the pointers Ben. I will look for the mud prawn version and fish it near weed beds in the rivers where the grunter and leerie patrol. I hope to get enough distance as these lures only weigh 3.2g.
Ben REINERS
I wanted to ad that you should consider tiny to medium sized split shot infront of the lure on yr trace line.....+- 10-20cm away & test the weight till you have the correct 1 for getting a little distance & taking the lure down to the bottom.
duckbill
Yes thanks that makes sense. I will definitely try it. But for now it is time to target some winter species. Vrote rooiaas and wurms. ;)
duckbill
So I made a few casts with the clear shrimp in Sedgefield. The mullet followed it on slow and fast retrieves, but I failed to get a strike. I did get a mullet on a piece of sardine on a size 8 circle hook. It went back into the water to join the rest of the shoal.
Saw a few dead fish on the river bank, including a small grunter and what looked like a carp. I think the mouth is currently closed and don't know if it's a good idea to eat anything from the lagoon.
The next day I scratched for some kollies in my secret Jan Bruin hole and got a small stompie and kollie. Also got a nice kollie in another hole which went to the pan. White mussel did the trick and I was using a 10ft Loomis Shockwave rod with a 4000 Daiwa grinder loaded with 20lb braid. Nice combo for scratching.
Ben REINERS
It will take you a few outings on trial & error & all conditions permitting when you will swear by the tiny creature to give you lotsa fun.
When all the bigger lures & baits fail the tiny creature livens up the water.
I agree, I would also be sceptical if I come accross dead fish....
Hope you put the shrimps thru its paces with more casts & catch sone trophies.
duckbill
Hi Ben
I will fish the shrimpies properly in summer. Will rig up my lightest combo with a shrimp and fish it when nothing shows interest in the bigger lures. It has an awesome action and I'm positive I'll eventually catch something on it.
I've experienced it first hand that when things are quiet the smaller lures often get hit. I will report any catches made on the shrimp.
Ben REINERS
Patience, & a serious of variations in yr retrieve/pause actions should do the job.....esp. on the bottom where it can make contact with the bottom, kick up a bit of mud or sand.....action should be On soon. Good luck.
duckbill
Recently I tried my shrimp lure in the Knysna lagoon. I retrieved it slowly and twitched the rod like you would when fishing dropshot minnows.
After about ten casts I got followed by a young leerie thrice, and thereafter two puffer fish started following the lure. One of them had a go at the lure, but the hooks missed.
After moving to another, shallower spot, I hooked a nice cuttle fish that eventually came off the hook. They are not easy to land.
Ben REINERS
Nice going Duckbill....you have enticed them, now to catch some more.
How about changing those tiny trebles for 2 In-line hooks ?
My reasoning will be less hook ups or snags on the bottom when bounced along & with most species taking it aggressively & almost inhaling it, the In-line hook will most definitely do its job & set.
Enjoy the outings & experience::tight:
duckbill
Hi Ben
It's like you've read my mind. I have a packet of small inline hooks somewhere that I can use to replace the treble hooks with.
I can tell that this will be my new favorite lure very soon. I managed to find one that looks exactly like a mud prawn. This specific one got the chases in Knysna. I've had some chases on the pink and clear ones as well.
